Base Board heat; better or worse...? - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 14th, 2008, 10:59 AM   #21
steveo
In the band!
I'd like to do a system over a field (horizontal) instead of drilling down to do it (vertical).
The way my property is set up, there are either too many trees where it could run, or drilling rigs couldn't get to where they could put it.
Plus, right now, I'm way too lazy to do it. I'd like to do radiant in-floor heating if I went with geothermal and all my floors are finished. Hell, I'd love to drop the same amount of cash as I would spend on a devent used vehicle and be off of propane.
my grandfather spenty less than 4500 dollars and used his existing water well.
Old December 14th, 2008, 11:00 AM   #22
brewchief
Originally Posted by Rainbird1099 View Post
Thanks guys for all of the feedback, The unit isn't loud, I opened the doors so I could here it run, and see how fast it gets warm.
I was happy with how it worked. I did find it has a leak, slight drip coming from the relief valve, the padding under the carpet has gotten wet for 6 or 8 feet outside of the closet, so this should give me more negotiating power.
As far as A/C goes, we work all day too, i have 2 window units in my little house here, and they seam to do the trick. We'll bring those to the new place, and have to hope it is enough.
A leaky relief valve is often caused by something else, most commonly a bad expansion tank(if diaphrapm), if it's a old style air/water tank it could just be waterlogged, bad fill valve would be next on the list and of course it could simply be a bad relief valve. Does it only leak when it heating up and then stop when it's cooling down?
Brewchief
brewchief is offline   Reply With Quote
Old December 14th, 2008, 04:08 PM   #23
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
NO WAI!
I think my well goes about 212' too...
@clarkstoncracker
Old December 14th, 2008, 04:08 PM   #24
steveo
In the band!
NO WAI!
very good, farther than his.
Page generated in 0.18043 seconds with 34 queries
