Staang's XJ build - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 12th, 2008, 05:41 PM   #1
Staang
Wheelin adict
Staang's Avatar
Default Staang's XJ build
So I have been building my rig for a few years now.
Here are some of the major mods I have done. I started with a bone stock 86 XJ.
The ones I dont have pics for are...
Regeared diffs to 4.56's
Engine (2.5L) rebuild and fuel injection swap to 97 TJ MPFI.
Steering box stiffeners...welded to the frame..and replacing the sh*tty aluminum spacer with dom tubing all the way through the frame.
I also fabbed a front longarm kit here are some pics.
I started with a box of Johnny Joints and bushings.
The test fit
and the final product
and finish install
Staang is offline   Reply With Quote
Old December 12th, 2008, 06:27 PM   #2
Staang
Wheelin adict
Staang's Avatar
After the front longarms were installed and I felt how much the ride improved I just had to start a rear coil conversion / longarm install for the rear.
I placed another order for joints and bushings, also ordered a bunch of steel and went to work.
1st was to strengthen the frame with some home made frame stiffeners.
I made them from 1/8 mild steel and punch a sh*t load of holes to attach them firmly to the frame.
I then made some small plates to wrap the frame in the mid-rear section to accept the crossmember.
I then used the good ol 4 link calculator thanx to Pirate4x4 to firgure my geometry, and made up my links. They are 2x2 1/4 wall lowers and 1.5x1.5 1/8 wall uppers.
I designed the crossmember on the computer first to ensure proper fitment, then tacked it all together for a test fit.
I laid out everything on the floor before finish welding in the XJ.
Here are the spring buckets that were fabbed
I used original replacement front springs in the rear to start.
I cut out the rear framewhere the factory bumpstop was to make room for the upper spring mount.
Then put it all together to get this.
After onto an alignment rack to check the numbers. Then it was off to test it.
Rear: Front:
and yes my front axle is bent hence the negative camber.
Old December 12th, 2008, 06:36 PM   #3
Staang
Wheelin adict
Staang's Avatar
Future mods include a ford front dana 44 with 5.38's and a lockrite, and a ford 9" rear with 5.42's and an lockrite. I plan on replacing the lockrites with ARB's when the funds are available.
These are to support my new 36inch irocks that are going on in the spring.
I also have all the parts to do a 231 doubler, I'm just not sure if I'm gunna still use my factory 207 or if I should locate a d300.
Hope you all enjoy my build. I will be updating as I go along.
Old December 12th, 2008, 06:37 PM   #4
ddeadserious
ddeadserious's Avatar
Nice work.
ddeadserious is offline   Reply With Quote
Old December 12th, 2008, 07:12 PM   #5
Waychoff05
Waychoff05's Avatar
nice.. how did you cut the front fenders?
Waychoff05 is offline   Reply With Quote
Old December 12th, 2008, 07:16 PM   #6
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
Nice
Old December 12th, 2008, 07:21 PM   #7
Staang
Wheelin adict
Staang's Avatar
With a cut off wheel on a grinder.. I made a general cut to where I wanted (pretty much the dirt line where the fender flare was) then I slice up into the fender every inch or so to fold it so it would not cut my tires.
Old December 12th, 2008, 07:31 PM   #8
Staang
Wheelin adict
Staang's Avatar
I also made my own bumpers. here is how the front one started out.
Name:	frt winch bumper 001 with winch.jpg
Old December 12th, 2008, 09:21 PM   #9
LILL ZJ
LILL ZJ's Avatar
great work ... i see that your work is top notch, those rear lower shock mounts are asking for snagups way down there? again nice work so far.
LILL ZJ is offline   Reply With Quote
Old December 12th, 2008, 11:53 PM   #10
nick_n_ii
nick_n_ii's Avatar
Send a message via Yahoo to nick_n_ii
Very nice set up. YOu designed and built the parts? I ask cause they look very close to the Clayton's Long arm kits.. Very sweet though..
nick_n_ii is offline   Reply With Quote
Old December 12th, 2008, 11:59 PM   #11
1badzuk
1badzuk's Avatar
nice build
i was tinking it looked just like the claytom kit i put on a cherokee.....so if it is a claytons props to ya because you end up refabbing all of it any way.
1badzuk is offline   Reply With Quote
Old December 13th, 2008, 08:57 AM   #12
meise
Hey staang nice build.....Lets do that to my 91 runner....you in?
meise is offline   Reply With Quote
Old December 13th, 2008, 10:38 AM   #13
Staang
Wheelin adict
Staang's Avatar
Ya the shock mounts were just a quick attach as I didn't want to buy new shocks.
Yes I designed and built the parts with help from my awsome welder buddie, I used claytons for my ideas cause I liked the way they looked which is why they look similer. My setup cost less then half of what a Claytons setup is worth.
Old December 13th, 2008, 10:39 AM   #14
Staang
Wheelin adict
Staang's Avatar
Soon buddie very soon... Just get that soild axle.
Old January 31st, 2009, 09:44 PM   #15
Frankinjeep
Body damage?
Frankinjeep's Avatar
I run 36 13.50 bias iroks on my xj and I feel I get to much floatation on what ever I am on. I am new to wheeling but I have thought about going to a 10.50 to 12.50
Frankinjeep is offline   Reply With Quote
Old March 4th, 2009, 12:01 PM   #16
Staang
Wheelin adict
Staang's Avatar
UPDATE!!
Picked up some new parts... change of plans a lil.
I scored a 44-9" with 5.13s and a detroit for the front that I am rebuilding now and a matching 9" for the rear with 5.13s and a spool. Gunna check it and possably rebuild it aswell... just need to open it.
At the same time as these axle go in I will also be converting to rear disc brakes and a line lock for a parking brake.
Old March 4th, 2009, 12:51 PM   #17
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
Very nice work. Let me know if you have leftovers from those axles, I am working on a set just like it and need a couple things.
RIP FULLSIZE4LIFE
Old March 4th, 2009, 01:17 PM   #18
rockstarryan
rockstarryan's Avatar
nice work....do you still have all the measurements and amount of pieces to build this kit on file.....and if so would you ever sell instructions to build the kit you have came up with???
thank you
Ryan
rockstarryan is offline   Reply With Quote
Old March 4th, 2009, 01:54 PM   #19
Staang
Wheelin adict
Staang's Avatar
Thanx, Never really thought about selling instructions to build the kit. I do however offer a complete DIY kit, minus springs so you can install and set your own hieght.
Old March 4th, 2009, 01:55 PM   #20
Staang
Wheelin adict
Staang's Avatar
Not sure if I will have extras, but what would you be looking for?
Page generated in 0.62565 seconds with 84 queries
