weird gauge cluster problem - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 12th, 2006, 11:33 PM   #1
BowtieWrangler
BowtieWrangler's Avatar
Default weird gauge cluster problem
i have a 99 Dodge Ram 1500 360, and everynow n then my ABS light comes on a few seconds later my Air Bag light comes and the speedometer/tach drops to 0, then my odometer flashes a few times then every gauge drops to 0 and the odometer reads "No Bus" and then the check engine lights shows up with it......after a few minutes it goes away, any ideas?
BowtieWrangler is offline   Reply With Quote
Old May 13th, 2006, 05:56 AM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
loose ground somewhere. check all the connections and then check somemore. theres grounds under the carpet and from the cab to the frame.
Yetti
Old May 14th, 2006, 10:08 AM   #3
sonic
sonic's Avatar
Lose connector to the computer also. make sure there plugged in good. Did you do andy repairs recently?
sonic is offline   Reply With Quote
Old May 14th, 2006, 01:45 PM   #4
BowtieWrangler
i havent done anything to it recently, at the beginning of last summer i put the K&N FIPK and a tune up on it, and during the winter i had to change the collector bolts on the driver side, and this just started happening out of nowhere happend bout 3 or 4 times in the pass month or so
Old May 21st, 2006, 11:37 AM   #5
Yetti
Yetti's Avatar
I finally got to ask around about the cluster problem. the majority of guys at work thought it was a failing cluster. they have some internal problems that come with time from what I am told. you may want to check out a junk yard for a new one and see if the problem goes away.
Yetti
Old May 21st, 2006, 07:54 PM   #6
sonic
sonic's Avatar
Also have it checked for secondary codes. These dont always set the light on the dash.
Page generated in 0.25651 seconds with 41 queries
