Steering Issue.... - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 10th, 2008, 07:39 PM   #1
94KOTA
Buy American!
94KOTA's Avatar
Send a message via AIM to 94KOTA
Default Steering Issue....
I have a 94 explorer with a 3" body lift....I did the lift over a year ago
I installed the shaft extender on the steering shaft...
when i drive it now...it turns perfectally but when i go to bring the wheel back straight it is hard to bring it back and it wants to keep pulling the direction i turned....alignment is good and the steering shaft U-joint is also good, checked by holding below and above and turning shafts opposite...no play....could it be the steering box going bad or possibly ball joints??? the shaft has play. maybe 1/4 to 1/2 inch movement circular each way...
Im kind of lost now and Im kind of weary of driving in wintery conditions as is...
Thanks alot for any help...
94KOTA is offline   Reply With Quote
Old December 10th, 2008, 07:45 PM   #2
raise the front wheels off the ground
disconnect tie rods at the spindles
manual turn spindle left to right and see if you have any stiffness in the motion.....
also check the front axle joints for stiffness as they can do the same effect on steering.
Old December 10th, 2008, 07:46 PM   #3
Grunto
Grunto's Avatar
Send a message via AIM to Grunto
Something to do with a return line in your power steering system maybe? Relief valve in power steering pump?
Does it make a difference when you go faster?
Grunto is offline   Reply With Quote
Old December 11th, 2008, 09:07 AM   #4
94KOTA
Buy American!
94KOTA's Avatar
no it doesnt make a difference when i go faster...any speed
Old December 11th, 2008, 06:32 PM   #5
booblinker
Sore and Tired 24/7
booblinker's Avatar
X2 On Wheel Joints, I had that happen on My Bronco not that long ago and that was the problem.
Old December 12th, 2008, 06:42 PM   #6
94KOTA
Buy American!
94KOTA's Avatar
Yea i took it in today to an alignment shop....Front wheel U-joints are shot and ball joints are gettin bad....$600....if it wasnt so cold and done them before id do it ...but am more than happy to learn:).....
Old December 12th, 2008, 06:48 PM   #7
booblinker
Sore and Tired 24/7
booblinker's Avatar
$600 for U-joints and ball joints? Seems like a good deal, Ball joints are $25 a piece, and u-joints are $20 a piece. If that includes alignment that seems cheap in todays shops.
Old December 12th, 2008, 07:12 PM   #8
94KOTA
Buy American!
94KOTA's Avatar
yea...its not bad...but im in college lol....and i love workin on my cars...but i havent done u-joints yet....
Old December 12th, 2008, 07:37 PM   #9
booblinker
Sore and Tired 24/7
booblinker's Avatar
If you havent had the work done yet then call your local auto parts store(nape, auto value, or independent, not murrays or zone) and the should be able to change the joints for you if you take the shaft in to them. Same thing with ball joints, take the whole spindle in and they can change it too. I work at an auto value and we would probably charge you ~$60 for 4 ball joints and 2 U-joints.
Old December 12th, 2008, 08:49 PM   #10
88mudder
In the band!
if u still lived down here we could do it , ive done both on a couple RBV's and its not hard.
Old December 14th, 2008, 02:30 AM   #11
94KOTA
Buy American!
94KOTA's Avatar
now that its gotten a lil warmer up here seems like they loosened up a little bit and it steers pretty good now, alot smoother but you can still here the loose joints....i dont have 4x4 right now and pry wont til spring....is it alright to drive it as is as long as 4x4 isnt engaged?....
Old December 14th, 2008, 10:33 AM   #12
booblinker
Sore and Tired 24/7
booblinker's Avatar
Yes, as long as you don't engage 4x4 you won't hurt anything.
Page generated in 0.23557 seconds with 59 queries
