97 ram tranny? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 9th, 2008, 08:21 PM   #1
muddy maki
Its tough out there.
muddy maki's Avatar
Send a message via AIM to muddy maki
Default 97 ram tranny?
what trans came behing the 97 ram 1500 magnum 318 and 360's?
is it worth a shit?
any common failures?
average milage it lasts?
just playing with the idea of a 318 or 360 swap in my jeep
figured the more i can get from a doner truck the better.
muddy maki is offline   Reply With Quote
Old December 11th, 2008, 05:34 PM   #2
muddy maki
muddy maki's Avatar
hmmm
Old December 12th, 2008, 09:37 AM   #3
nickb304
nickb304's Avatar
second gen rams came with the 46re or 46rh. a friend of mine ran his 210k before he sold the truck and mine gave up 80k on my 02. trans is ok, but coverter and valve body issues cause the failures. i guess they can be built up solid for big money but you would be better off with the new hemi and 545rfe trans. or hemi and 6-speed manual out of a 3/4 ton.
nickb304 is offline   Reply With Quote
Old December 12th, 2008, 10:22 AM   #4
84Scrambler
A '97 would have a 46re behind the 360. They stopped using the 46rh in '95. The 46re lasts a little longer than the 44re that was behind the 318's, but not much. Anything over 80k is a gift with those trannies.
Old December 12th, 2008, 10:26 AM   #5
bigjay
The Man Myth And Legend
bigjay's Avatar
Location: i can piss on the allegan and barry county line at the same time.. ...
have 200000 on my stock trans
bigjay is offline   Reply With Quote
Old December 12th, 2008, 10:34 AM   #6
silveranger93
silveranger93's Avatar
The new 3/4 ton Hemi's get a 6-speed? My parents have an '04 2500 Hemi with the 5-speed manual...that thing rips with the 4.10 rear...
My '97 Ram with the 5.9L is on its 4th trans in 150K miles, everything else is perfect on the truck, just likes to chew the trans up every 40k or so miles. It does see a LOT of towing, much of it through mountains (I'm from PA and travel home quite a bit).
silveranger93 is offline   Reply With Quote
Old December 12th, 2008, 10:53 AM   #7
nickb304
nickb304's Avatar
your right they were a 5 speed. 6 speeds came with the ctd. can't get a hemi with a manual for 09 by the looks of it.
Old December 12th, 2008, 10:56 AM   #8
silveranger93
I know when they got theirs, you couldn't get a 1500 with a manual Hemi. They special ordered theirs (no one wanted to touch it, in case they backed out and they would be stuck with a stick Hemi), it took I think 9 months for them to get it after they ordered it.
Old December 14th, 2008, 02:01 PM   #9
muddy maki
muddy maki's Avatar
ill take that as advice that i should have the doner trans rebuilt or get a reman unit before the swap. thanks guys!
Old December 14th, 2008, 02:30 PM   #10
TIRES_ARNT_CHEAP
that trans is junk bro. service tech @ milosch dodge
TIRES_ARNT_CHEAP is offline   Reply With Quote
Old December 15th, 2008, 10:25 PM   #11
muddy maki
muddy maki's Avatar
thats what ive been hearing.
looking into other auto transmissions options hopeing to find one that is a direct swap in between a 5.2 or 5.9 and a 231. i dont want to speend an ass tone on adapters.
Old January 11th, 2009, 03:01 PM   #12
mprmn08
mprmn08's Avatar
honestly its not the trans itself thats bad. its usually the convertor or VB that messes stuff up. I had mine built up for 800 and that included a new convertor and the guy gaurentted it wouldnt break for what i was doin. (wheeling and towing) alls you have to do is upgrade the VB and convertor and replace the wave clips in there with flat ones out of a 727 or something. the wave clips like to break cause the clutch packs to come apart. so its all in how you look at it i guess. yes they go bad but they can be made to handle whatever for not much money at all.
Old January 15th, 2009, 05:32 PM   #13
snocross2xtremes
snocross2xtremes's Avatar
you can run a 727 behind one. thats whats in my jeep.
Old January 24th, 2009, 04:13 PM   #14
kruzh
kruzh's Avatar
who did your upgrades for you? i have over 200,000 miles on my tranny (stock).
kruzh is offline   Reply With Quote
Old January 24th, 2009, 04:35 PM   #15
mprmn08
mprmn08's Avatar
a guy out of grand rapids did mine. he works out of his garage but he knows his stuff when it comes to dodge transmissions. he does most of the dodge trans's at u.s. 131 dragway. pm me or something if you want his number and name.
Old February 16th, 2009, 08:31 AM   #16
snodevil
snodevil's Avatar
Location: Berkley, MI 48072 / Indian River, MI 49749 (cottage)
Send a message via AIM to snodevil Send a message via MSN to snodevil
or run a manual trans. nv3500 or nv4500 w/ 23 spline output will both bolt to your 231. I have the 318 and 3500 I'm putting in my TJ. Also plan to build the 360 core I have to swap in latter with a 4500. Should be pretty bulletproof then.
snodevil is offline   Reply With Quote
Old May 30th, 2009, 03:36 PM   #17
Never_Evil
When it comes to Dodge Tranny's, you have to adjust the bands on EVERY tranny filter change. When you change your tranny fluid every 35000 to 40000 miles, you can adjust the tension on your bands to prevent them from slipping and then ruining the transmission. I've had a Mopar guy explain that its simple, but get a book to make sure what your tolerances should be.
Old June 1st, 2009, 02:14 PM   #18
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
x2
I have had good luck, but I keep the maint. up to date.
RIP FULLSIZE4LIFE
Page generated in 0.35084 seconds with 77 queries
