| Home | Register | iTrader | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Store | Photo Gallery | Chat |
Thread Tools |
#1 |
"The Situation"
Buick 350 tech..
Just started to reasemble my engine for the Heep. got the cam all lubed up and started to slide her in. got almost in til the last bearing, and it bound up. wouldnt turn or go in any farther..
this being my 6th engine, ive NEVER had this problem.. Machine shop guy says the cam bore is out of round but yet you can see a contact mark on the bearing All the way around? and it doesnt get thinnner or thicker at any point ? Any input ? Motor is a 69 buick 350 |
#2 |
Buy a Fiat! Save the UAW!
sounds like your machine shop guys is a lazy f**k. cam journals can't get out of round. and the tool that installs them is very picky. if he screwed up he should suck it up and put in a new bearing.
I have built hundreds of Gm engines and the cam bearings aren't that hard to do right. I had a couple of guys bring me bench jobs that were screwed up because of poor service at the machine shop. |
#4 |
Yankabilly
Chances are if the cam bearings are new they have the cam bearings installed in the wrong order.
#5 | |
"The Situation"
I was not aware that sizes differed.. i just figured he had one not perfectly square to the block so i pulled the block off the stand and stood it up just to feed that rear cam lobe into that particular bearing and still no dice.... i contacted him and hes going to fix at no charge. just irritates me to loose almost the whole weekend or working on it
#6 |
just to clarify things, some older engines had the bearings ground in steps. the first 4 would be one size and the one on the tail would be a bit smaller. I don't know why it was done that way, it just was one a few engines.
#8 |
Ranger Addiction?
For the rope seals, soak them in oil for a good 2 days (a day will probably do, but just to make sure), then just jam them in, and try not to squish too much of the oil out (again, just to be sure).
It really isn't that much different than a regular 2 piece seal, or are the rope chunks the guy sold you a shit ton bigger than the slots? |
#9 |
"The Situation"
Well thats the thing im not 100% sure what slot its supposed to go in. im preatty sure its the outer one because i can see a imprint on the crakn from where the old seal sat, if thats the case then yes the rope seal is a shit ton bigger :tonka:
#10 |
Ranger Addiction?
I'm just wondering because the rope seals on the 8N I rebuilt were at least 1/2" wide.
Sooo, this seal is alot bigger than where it looks like it goes. Did you buy the engine apart or complete? Seems a little on the late side for rope seals to me.. Well, I'm out for ideas.. |
#12 |
Capt. I never heard of soaking rope seals...ever.
the biggest thing to remember on rope seals is to "pack them" they have to be jammed into the outside grove and the ends of the rope cut long so they can be packed into the grooves while the crank is in place. the biggest trick is to off set them. leaving one side long on the block while leaving the opposite side long in the cap. if you can pack the end in on the long sides recieving side and it should pack into the groove when you tighten the cap. you have to use forma gasket or anarobic seal on the rest of the cap to prevent oil from leaking between the block & cap. good luck. by the way they make rubber replacement seals...call a parts store. |
#14 | |
Then you need to call more stores or order one. You live in Fenton. Do you know how many bazillion parts stores there are in Oakland and Genessee counties? |
#15 | |
"The Situation"
#16 | |
Ranger Addiction?
But it would seem to me that it would just wear right out if not jam packed with oil.. being a couple thousand RPM, slightly oiled steel on a dry surface (for a while at least, eventually it would soak up alot of oil) heh.. come to think of it.. I had a set to seal the back of my transmission soaking since I left for college in the fall lol, probably still sitting on my hood. |
#18 |
Ranger Addiction?
Not enough rope or oil? I was told just engine oil will do, gear oil would probably work nice too, few extra additives.
I don't see how having more oil on something like that could hurt it. |
#19 | |
Yeah, well that philosophy doesn't get shit fixed. Its also known as "not willing to do what needs to be done in order to do the job correctly". |
#20 | |
"The Situation"
| Thread Tools | |
