14 bolt shortening question... think about this.. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 11th, 2006, 10:37 PM   #1
clarkstoncracker
lol
clarkstoncracker's Avatar
Default 14 bolt shortening question... think about this..
an offcenter 14bolt.
Cut the long side to make it equal to the short side.
then you can just run two short shafts, and only need to keep one spare.
hosejockey had this idea, you guys see a problem with it?
It iwll be the exact same length as a dana 44
Old May 11th, 2006, 10:58 PM   #2
biohazardbill
The Biohazards
biohazardbill's Avatar
Seems feasible, just order a custom set of spare axle shafts just in case...
biohazardbill is offline   Reply With Quote
Old May 11th, 2006, 11:03 PM   #3
clarkstoncracker
lol
but if you cut the long side down to a short side length, then you just have to keep one stock short side axle as a spare for either side
there has to be a reason this won't work, because I can't find anybody who has done it
Old May 11th, 2006, 11:12 PM   #4
biohazardbill
The Biohazards
people shorten axles every day lol
Old May 11th, 2006, 11:22 PM   #5
Ebs
It seems like a lot of work for little benefit.
You can already narrow a 14 bolt to 63" without doing any work, how narrow are you looking to go?
14 bolts are cheap and plentiful, so even though your cutting down on the number of replacement parts you need you really wouldn't be saving much, other then the need to carry one less axleshaft (if you see the need to carry spare shafts in the first place).
I guess if your only option was to chop and narrow the axle it would make sense to keep it simple and use factory length shafts instead of custom jobs.
Old May 12th, 2006, 03:16 AM   #6
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
It will work with no issues.
Score a straight line down the length of the axle tube.
Cut long side tube about in half.
Measure ID of axle tube.
Order DOM tube with same OD (or up to a .010 larger for a press fit)
You probably will have to mill a small slot down the DOM tube for the seam inside the axle tube.
Section housing to desired width
Camfer tube ends for a good weld
Press two housing peices together using a length of the DOM inside to align them.
Weld it up around the cut and with plug welds if you prefer.
The sleeve will keep everything straight and strong.
JcrOffroad
Zoom Zoom!
Old May 12th, 2006, 09:05 AM   #7
Yep, Monkey's method shoudl work.
Don't just cut and butt-weld.. seen it done, it broke on the trail..
Don't let swampjeep drive it, it'll break, too. :tonka:
Bastard Year (72-75) CJ-5s run Dana 44s with shafts that are the same left and right. Others do too, so the concept isn't new.
Have you checked what the left-right offset of the pinion would be for your driveshaft?
Old May 12th, 2006, 11:46 AM   #8
PavementPounder
PavementPounder's Avatar
Its becasue:
- Most people buy axles that are a width that will work for them in the first place.
- People usually go for the 35-spline units and don't break them anyway.
- 14b's are too common to bother with this if the stock width is not a problem for you.
- People that buy 14b's because they think that it will be cheaper to build (than say, a Dana 70), always find ways to prove themselves wrong by trying stuff like this.
The concept is sound, like Jesus and others have said. I just don't think its really necessary with what you're working with. I mean, anybody will give you a lift back out the Mounds parking lot :tonka: to get the stock spares out of your tow rig. Not to mention it blows your whole financially-based argument for buying the 14b in the first place.
Now I have to go pull my shafts this weekend because I can't remember if that was one of the things that was done, or if they were equal anyway.
Old May 26th, 2006, 12:00 PM   #9
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
shortening is not an issue... and is a good Idea as to only keeping one shaft as a spare. With the 14 bolt I ran I only broke one stock rear axle shaft and I was hard on it in my 78 blazer, 84 blazer, 85 short box chevy, and Cj-7. I broke it when it was in the 84 blazer 8,000 rpm's when the wheels touched back to the ground and snap :tonka: :tonka:
The wheeling you do I don't see an issue of you ever breaking them, especially being half the weight the blazer was. But axles can and do break especially when a tire is bound in a crack and not moving under full throttle.
Old May 29th, 2006, 09:36 AM   #10
Strangler
Strangler's Avatar
Just buy my c&c hubs. $50
Page generated in 0.21989 seconds with 53 queries
