Black Powder rifles FS/FT - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 3rd, 2008, 11:20 AM   #1
jeepster95
Happy 2b Jeepin!
jeepster95's Avatar
Default Black Powder rifles FS/FT
Continental Valley Arms .54 cal with composite stock, great shape, only used a couple times
CVA .50 cal old style (flint lock style ??) i believe it was a kit type hex barrell
shoots good
[IMG][/IMG]
$200.00 for both or would trade for Drum set, Guitars or Car amp and sub box
jeepster95 is offline   Reply With Quote
Old December 4th, 2008, 07:16 AM   #2
tweak
Are we there yet?
tweak's Avatar
PM Sent
Old December 4th, 2008, 07:23 AM   #3
jeffandjess4806
In the garage
jeffandjess4806's Avatar
I have this it's a big AMP, I had this in my truck pushing 8" kicker way to much power for that we had it turned all the wat down and was still to much power.
jolney@springcom.com
Info from web
To those who are about to rock, Rockford Fosgate built the Power 750S for you! This slammin' amp pumps out 187.5 watts RMS per channel, bringing new power and depth to your music with cutting-edge technology and innovative circuitry. Go ahead and drive this amp hard — the special-design preamp section cranks things up without a trace of distortion, while MOSFET output devices provide the muscle needed for extreme performance with absolute accuracy.
With the built-in high- and low-pass crossovers, you can configure the 750S for different applications — driving subwoofers, full-range speakers, or components. Bridge the 750S to deliver an awesome 750 watts, and use the wired remote control to dial in the Punch Bass (up to 18 dB of bass boost at 45 Hz). If space is an issue, you can remove the amplifier's endcaps for a smaller profile.
Details:
187.5 watts RMS x 2 at 4 ohms
375 watts RMS x 2 at 2 ohms
750 watts RMS x 1 at 4 ohms in bridged mode
amplifier requires one 60-amp fuse (not supplied)
stereo or bridged mono output
Tri-way capable (Tri-Way crossover required)
MOSFET power supply and output devices
50-250 Hz high-pass/low-pass crossovers, 24 dB/octave slopes
MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
TOPAZ — noise-killing differential inputs that eliminate 80% of ground loop noise
trans•ana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality
NOMAD — advanced protection circuitry for "intelligent" shutdown protection
wired remote control included for fingertip control of Punch Bass (for 0-18 dB of bass boost at 45 Hz)
preamp-level (RCA) inputs
preamp (RCA) outputs
requires 4-gauge power and ground leads — wiring and hardware not included with amplifier
dimensions: 18-7/16"W (14-7/8" without endcaps) x 2-7/16"H x 9-7/8"D
jeffandjess4806 is offline   Reply With Quote
Old December 4th, 2008, 01:03 PM   #4
matt3liv
matt3liv's Avatar
is the 54 a percussion cap or 209 primer?
matt3liv is offline   Reply With Quote
Old December 8th, 2008, 11:22 AM   #5
jeepster95
Happy 2b Jeepin!
jeepster95's Avatar
[/IMG]bump
Old December 8th, 2008, 11:32 AM   #6
gehtowheeler
what dreams are made of
gehtowheeler's Avatar
Send a message via AIM to gehtowheeler
bass gutair and amp cord and foot tuner for the traditionals wood one
amp is ibonez
bass is dean
various gutiar cords
tuner pedal for tunning guitar
gehtowheeler is offline   Reply With Quote
Old December 8th, 2008, 12:43 PM   #7
Jeepunk95
would you trade for kicker CVR 10" sub with very large carpeted box. i would take one of the guns if you wanna keep one and trade soemone else for an amp ?
Jeepunk95 is offline   Reply With Quote
Old December 15th, 2008, 03:38 AM   #8
feelsoright03
feels so right
feelsoright03's Avatar
Send a message via AIM to feelsoright03 Send a message via MSN to feelsoright03
I got a alpine 10" typR with a 2400 watt directed amp in a box. Or I got two 10" audiobahns with a 800 watt kenwood amp in a box. Both boxs will fit in the back of a YJ. Would like to trade for both guns. I paid $200 for the alpine brand new and paid $350 for the directed amp. I just bought the audiobahn and kenwood setup from a friend for $200 cause she needed money.
~Teddy~
feelsoright03 is offline   Reply With Quote
Old December 15th, 2008, 07:28 AM   #9
jeepster95
Happy 2b Jeepin!
jeepster95's Avatar
i have a possible deal pending, just trying to finish it, if it falls through i will let you know
Old December 16th, 2008, 12:53 AM   #10
feelsoright03
feels so right
alright thanks let me know.
~Teddy~
Page generated in 0.38264 seconds with 53 queries
