polymer coated bullets - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > Other Stuff > The Great Outdoors
The Great Outdoors Guns, Cannons, Fishing, Camping, and other fun stuff
Old December 3rd, 2008, 09:16 AM   #1
Bones
Bones's Avatar
Default polymer coated bullets
Newbie question - Do they help with wear, or cause more problems?
http://www.sportsmansguide.com/net/cb/cb.aspx?a=70819
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old December 3rd, 2008, 09:30 AM   #2
TFin04
Only the casing is polymer coated. The bullet is the copper colored part on your picture.
The Wolf cases are steel then given a dry polymer coating. They are dirtier and a little less consistant than other brass cased ammo, but they usually run fine. I have shot tens of thousands of rounds of Wolf through multiple different guns without issue.
What gun are you planning to run it through?
TFin04 is offline   Reply With Quote
Old December 3rd, 2008, 09:31 AM   #3
Bones
Bones's Avatar
Taurus PT140
I guess my question is, what is the advantage to the polymer
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old December 3rd, 2008, 09:32 AM   #4
ckhanna71
ckhanna71's Avatar
very dirty stuff, but I would think it would be fine as long as your very anal on cleaning the gun. I have had a couple gun shops recommend not using it though...
ckhanna71 is offline   Reply With Quote
Old December 3rd, 2008, 09:37 AM   #5
TFin04
Originally Posted by Bones View Post
Taurus PT140
There is no "advantage" it's just the way they make steel cased ammo. Obviously steel is harder than brass so the polymer helps to keep the case from rusting during storage and feeding while shooting. The stuff is cheap, if you don't plan to keep the cases to reload just shoot the wolf.
It isn't that bad. I have shot the hell out of this stuff through my Glocks before I started reloading. My AK has over 10k rounds through it without cleaning. Granted it's an AK and they will shoot about anything, the inside isn't that dirty. I used to only clean my AR every 2k rounds or so and shot a ton of wolf through that gun as well.
Old December 3rd, 2008, 09:39 AM   #6
ckhanna71
ckhanna71's Avatar
I have heard that it will gum things up more than just be dirty I guess is what I meant to say. But honestly, they scared me away from shooting them so I don't have actual proof.
Old December 3rd, 2008, 09:44 AM   #7
TFin04
You are correct that it IS dirtier than other options, but it isn't so bad that you have to be a cleaning nazi with it.
Old December 3rd, 2008, 02:00 PM   #8
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Really depends on the tightness of your action, chamber, etc...
My Kahr probably would not like them, mostly because it's picky, but mosts glocks would NOM NOM NOM just about anything.
JcrOffroad
Zoom Zoom!
Old December 3rd, 2008, 02:02 PM   #9
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
they actually shoot suprisingly well out of my xd.
Old December 7th, 2008, 09:31 PM   #10
steveo
In the band!
steel cased ammo does not expand and seal the chamber like brass cased does. this allows the super dirty powder wolf uses to get between the case and the chamber walls. the polymer is supposed to help keep it from sticking. most people usually only have a problem when switching from steel to brass, the brass expands in the dirty chamber and sticks. i have shot thousands of wolf rounds out of my mak 90, g23 and ar15 with good results, but i am anal about cleaning them.
Old December 8th, 2008, 11:54 AM   #11
TFin04
Mic an unfired steel case and a fired one. They expand just fine.
Old December 11th, 2008, 01:54 PM   #12
Stan
I got a gold chain
Stan's Avatar
You'll shoot your eye out.
Stan is offline   Reply With Quote
Old December 11th, 2008, 03:17 PM   #13
steveo
In the band!
really? have to check that out.
Old December 11th, 2008, 03:24 PM   #14
oz97tj
Wasn't this attached?
oz97tj's Avatar
Really, you should be cleaning the weapon after a day of shooting anyway so you shouldn't have a problem. I've used Wolf numerous times because it's cheap. I've never had a problem. But like I said, I clean my weapons after shooting them too. I never leave a weapon dirty. Then again, I use mine for work and my life could depend on it so I guess I'm picky.
They way I see it, it takes less than 10 minutes to do a decent cleaning so I just do it.
********GLFWDA.org********
Old December 11th, 2008, 03:29 PM   #15
steveo
In the band!
no kidding. who would spend 1100 dollars on a rifle and then not bother to clean it?
Old December 11th, 2008, 06:12 PM   #16
Nuggets
I fix stuff!
Nuggets's Avatar
I'm cleaning my "weapon" right now.
Old December 16th, 2008, 11:30 AM   #17
joel216
joel216's Avatar
The stuff jams my Marlin .44 mag every time. It is not the easiest to tare down to unload.
joel216 is offline   Reply With Quote
Old December 16th, 2008, 02:04 PM   #18
Guitardrumr
Guitardrumr's Avatar
Send a message via AIM to Guitardrumr
http://www.theboxotruth.com/docs/edu18.htm
Great website, with lots of fun stuff on it.
Guitardrumr is offline   Reply With Quote
Old December 16th, 2008, 02:32 PM   #19
cham
Inconsistant at Best.
It isn't that bad. I have shot the hell out of this stuff through my Glocks before I started reloading. My AK has over 10k rounds through it without cleaning. Granted it's an AK and they will shoot about anything, the inside isn't that dirty. I used to only clean my AR every 2k rounds or so and shot a ton of wolf through that gun as well.[/QUOTE]
it fucked up my glock 21, something happened while feeding that caused half the extractor to break off, which in turn allowed the round to chamber but there was too much of a clearance for the firing pin to properly strike it and it would jam.
cham is offline   Reply With Quote
Old December 16th, 2008, 03:02 PM   #20
Rebel2345
NOT GL4x4SucksVideo guy.
Rebel2345's Avatar
The Wolf ammo I've been getting are copper coated steel bullets. It might only be the 7.62 I've been getting, but sanding the copper coat off of the rounds I've been shooting out of my SKS told me that the copper coat is only .001 thick.
I know most dont take a magnet with them everywhere, but my advice would be not to fire this stuff out of expensive rifles like AR's if a magnet sticks to the bullet itself. I was taught that it will contribute to damaging the rifling.
Page generated in 0.32018 seconds with 84 queries
