EB44 disk conversion - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 2nd, 2008, 08:23 PM   #1
88mudder
In the band!
Default EB44 disk conversion
what do you all recommend for converting a EB44 axle to disk brakes? Will the outers on a fullsize 44 Ford axle bolt right onto the EB axle? Will i have to swap knuckles? New to this and trying to gain as much knowledge about it before i start.
some options ive discovered:
-Chevy Flat tops/high steer arms and TRE's, Chevy disks, chevy outer shaft and Ford Hubs (i still dont know if i want high steer or not, this isnt a decicated wheeler rig)
-Fullsize Ford 44 outers (like said above, will this work without swapping on the fullsize 44 knuckle?)
-Conversion kit ($500 bucks)
Old December 2nd, 2008, 08:36 PM   #2
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
google is a very handy tool
But I am feeling nice;
1. use chevy small bearing spindles and calipers with brackets, ford hubs and rotors
2. swap on knuckles and all from a full size
Old December 2nd, 2008, 08:46 PM   #3
88mudder
In the band!
I think the Chevy swap is what im going to do since i have access to a small bearing spindle 73 Blazer axle with flat tops and arms.
Old December 2nd, 2008, 08:52 PM   #4
Jeepaholic
Jeepaholic's Avatar
yes, it should have the small bearing spindles also
Old December 2nd, 2008, 08:54 PM   #5
88mudder
In the band!
thanks, sorry edited the post at same time you posted and yes this does have small bearing spindles.
Old December 2nd, 2008, 09:03 PM   #6
Jeepaholic
Jeepaholic's Avatar
use the chevy bearings in the ford hubs though.
Old December 3rd, 2008, 08:05 PM   #7
88mudder
In the band!
thx 99grand
Old December 5th, 2008, 11:42 AM   #8
halfgassed
halfgassed's Avatar
you dont even need to put the chevy knuckles on.
If you still have the factory EB d-44 DRUM brake knuckles, the chevy small bearing spindles/backing plates/calipers all bolt onto the factory drum knuckle. You'll have to do a very minimal grinding on the caliper to clear the a small spot on the knuckle (IIRC)
This also allows you to keep the stock EB d-44 tierod.
halfgassed is offline   Reply With Quote
Old December 6th, 2008, 01:14 PM   #9
88mudder
In the band!
thanks i will try that first
Old December 25th, 2008, 03:20 PM   #10
BOGDOG
BOGDOG's Avatar
Jeff @ the Graveyard had an instruction sheet that was very detailed and listed all of the parts and hardware required. It is avery easy swap.
Old December 29th, 2008, 04:58 PM   #11
88mudder
In the band!
nvm figured that out.
How about TTB 44 outers..will those bolt onto a solid 44? I can get some for a fair deal.
Page generated in 0.36370 seconds with 56 queries
