axle leak and a noise - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 18th, 2005, 11:50 AM   #1
Lothos
KD8GKB
Lothos's Avatar
Default axle leak and a noise
I was changing the gear lube out of my axles this past weekend when i noticed a bit of weepage out the right side. I'm also hearing a rythmic noise from the front right area when driving. How reliable are the axle seals if any and which end are they on? Are they easy to replace?
Old November 18th, 2005, 12:15 PM   #2
PavementPounder
PavementPounder's Avatar
Bad bearing will cause the seal to leak. Pain in the ass to fix. Have to take everything off to get to them.
Old November 18th, 2005, 12:20 PM   #3
Lothos
KD8GKB
Lothos's Avatar
Bearing on the pig end? I didn't think there was one one the wheel end aside from the hub/bearing assembly.
Old November 19th, 2005, 01:44 AM   #4
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
yes they are at the pig end. All must be removed to fix. The rythmic sound is most likely bad bearings.
Page generated in 0.20092 seconds with 35 queries
