Trailer Brakes Help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 1st, 2008, 10:34 PM   #1
Default Trailer Brakes Help
Recently purchased a 92 F250, it had a brake controller installed on the bottom of the dash.
Looked under the box and the wiring was needless to say a NASTY mess. So i went to the junkyard and pulled a harness from a non-hacked truck. Installed the harness on my truck. Now my Truck apears to have the tow package being all the wires were present for the 7 blade trailer connector. The harness i pulled was a factory harness with the 7 blade connector present.
So i get it all wired in and done. I hook up my trailer and check all my lights. Everything is good. Now while driving i can move the controllers lever to activate the trailer brakes and it works as it should. But with normal braking (not physically touching the lever) and with the little power dial turned all the way up, the trailer brakes only seem to work 25% of the time and only apply on that 25% of the time at the very end of the stop. They do not assit at all. With the power dial turned all the way down the trailer does not brake at all ever.
Is the controller going bad? or maybe a shitty ground?
I used the trailer two weeks ago with my old Burb (now sold) and it worked just fine. The trailer itself isn't that old, i bought it new.
Old December 1st, 2008, 10:47 PM   #2
FORD FLARESIDE
Year 2 Griffins Travel
FORD FLARESIDE's Avatar
I have a viring diagram somewhere for trailers and Ford trucks. I will see if I can find it.
I had issues with my blue trailer (that Josh has) until I started over and rewired the whole thing. The previous owner had a 98 Chevy, and I think he did his own wiring without using the standard diagram.
Old December 1st, 2008, 10:49 PM   #3
the wiring is all factory except the actual control box
Old December 1st, 2008, 10:51 PM   #4
Nuggets
I fix stuff!
Nuggets's Avatar
I'm 87.6111% sure you have a bad controller.
Old December 2nd, 2008, 05:27 AM   #5
jhnyquest
goof ball
jhnyquest's Avatar
Sounds like its in the controller.
Old December 2nd, 2008, 07:30 AM   #6
SuperYooper
Thread killer
SuperYooper's Avatar
Are you sure your controller doesn't have two adjustment buttons? Mine has three 'things' on it - the push lever thingy that you can use to manually apply the brakes, the '% brakes' button, AND a 'sensitivity' button on the side of the unit. The sensitivity button has a range of 1 to 5, and if it is on 1 mine acts kind of like what you are describing.
SuperYooper is offline   Reply With Quote
Old December 2nd, 2008, 09:13 AM   #7
didn't look for a second adjustment, i'll have to take a peak when i go out later.
Old December 2nd, 2008, 10:46 AM   #8
CreativeFab
used to be Ironman
CreativeFab's Avatar
One way of testing your controller is to locate the brake "hot" at your female truck end, once located have someone apply the brake slowly and check for voltage change throughout the stroke. As the brake is applied the voltage should increase. If it is doing this at it's lowest output level check the maximum output at full pedal depression, then check it at the controllers highest setting and you should see a final output increase between the two.
If it stays the same you obviously have a controller issue.
Old December 2nd, 2008, 11:37 AM   #9
i'll have to check it out
My controller only has one dial or adjustment on it.
Old December 2nd, 2008, 07:20 PM   #10
so anybody know where i can get a good/cheap controller that is more of a direct bolt in for my 92 F250?
TSC wants 60-90
Napa was 100
Autozone was 60-80
but all those seemed uper cheap in design
Old December 2nd, 2008, 07:29 PM   #11
jeepnxj96
jeepnxj96's Avatar
I got one for my dads truck from autovalue here in Allegan, it was a Valley truck parts brand ???? seems to work well and EZ install. ohhh and it was like $80
Old December 3rd, 2008, 06:58 PM   #12
CreativeFab
used to be Ironman
TSC wants 60-90
Napa was 100
Autozone was 60-80
Give me a call, I sell all brands but the one I like and use in the, around $100 variety, is the DrawTite Activator ll
I'll hook a brother up!
Pat
Old December 3rd, 2008, 07:56 PM   #13
Trail Junkie
iamfawkinwithyou
Trail Junkie's Avatar
Look on all sides, I had a hard time finding the 2nd adj on mine
Old December 3rd, 2008, 08:04 PM   #14
Bow_Extreme
Bow_Extreme's Avatar
If you buy a new one, tekonsha is one of the best and you get what you pay for just like anything else.
Bow_Extreme is offline   Reply With Quote
Old December 3rd, 2008, 08:08 PM   #15
insaneoffroader
insaneoffroader's Avatar
i'll second tekonsha
insaneoffroader is offline   Reply With Quote
Old December 3rd, 2008, 09:25 PM   #16
Tacker
Tacker's Avatar
I'll third the Tekonsha/cequent controllers.
Old December 5th, 2008, 07:43 PM   #17
went and got a tekonsha voyager
spent some time driving around wiht the trailer trying to get them adjusted right. Sure makes me miss the controller i had in my old burb though. that one was a hydraulic unit so it self-adjusted brake pressure simply by the pressure you gave it with the brake pedal. I'll get the hang of it.
Page generated in 0.41722 seconds with 74 queries
