Oil pan problems.... - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 1st, 2008, 09:40 PM   #1
J/T
J/T's Avatar
Send a message via Yahoo to J/T
Default Oil pan problems....
I have an '85 4runner with a solid axle that I bought with an '89 4 runners
22re and if I hit something to hard I will hit the oil pan with the axle. So I was wondering which of my two ideas are better, add a leaf or two to get the clearance back or to just get the right oil pan?
J/T is offline   Reply With Quote
Old December 2nd, 2008, 02:09 AM   #2
skife
skife's Avatar
i wonder why the P/O didn't swap oil pans, I would have.
Old December 2nd, 2008, 05:40 AM   #3
J/T
J/T's Avatar
The guy couldn't put the original oil pan on because the original engine overheated and blew one rod out both sides of the block and through the oil pan.....
how ever he did that.
Old December 21st, 2008, 10:55 PM   #4
ToyinAround
Trust Me....
ToyinAround's Avatar
i did that once by hydrolocking the engine!
Well if u lift the front you'll have to lift the back... I'd try to fing the oil pan.
ToyinAround is offline   Reply With Quote
Old December 22nd, 2008, 02:15 AM   #5
skife
skife's Avatar
if you can't find a pan, you could also do a small body lift.
Old December 22nd, 2008, 02:37 AM   #6
OldSailor
AKA GreyShrink
OldSailor's Avatar
It's been a while since I've had a Toyota 4x4, but how is a body lift going to change the relationship between the engine and the axle?
Get a new oil pan -- maybe from a wrecking yard if new ones are too expensive.
Also, if you remove the oil pan that's on there now, can you get it modified to provide more clearance?
BTW, if you add a leaf or two to the suspension, you might want to increase the size of the bump stops to keep the axle from hitting the oil pan when you hit the big bumps off road.
OldSailor is offline   Reply With Quote
Old December 22nd, 2008, 07:54 PM   #7
J/T
J/T's Avatar
Thanks for the advice, I think I am going to do both the add a leaf and try to get an oil pan off of a non-ifs 4runner, just so I can make sure...
Old December 25th, 2008, 03:41 PM   #8
skife
skife's Avatar
wow, i wasn't even thinking about that.
good call man.
Old December 25th, 2008, 10:17 PM   #9
Mud'N'Truck
I'll Finsh One, One Day
Mud'N'Truck's Avatar
I know i have a 4x4 oil pan some were out in the garage id sell. Just have to find it. Its off my 85 from when i did my motor swap. Put the 22re from mine in a 2wd truck so i swapped pans so the 4x4 one is just sitting around some were.
Old January 20th, 2009, 06:22 AM   #10
J/T
J/T's Avatar
How much are you looking to get for the oil pan?
Page generated in 0.25598 seconds with 53 queries
