YJ Build (First One) Updated 5/12/13 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 29th, 2008, 08:59 PM   #1
TCP
Keep On Jeepin On
TCP's Avatar
Default YJ Build (First One) Updated 5/12/13
Like the rest of the first timers this is going to take a while and I'm learning as I go. Got a 1991 yj frame and axles from gmotox(great guy to deal with). Frame had v8 mounts and some rough spots. Ground off mounts, front panhard bracket, intermediate member and rear cross member (you'll see why in the pics). Had it beaded then it went to a buddy of mine, who is a great welder. There we started repairs. The thin spots he burned thru and filled in with the mig. I went behind and ground them down. Cut out the split section in front of the front panhard bracket welded in a new pc. Welded back on brackets, crossmembers and stock motor mounts. Ordered the crossmembers from moparpartsamerica.com. Intermediate crossmember didn't come with back supports so we had to fab some. Overall, I believe the frame is stronger now then when it came from the factory. Got it back to my place and put on two coats of POR15.
All sand blasting to be done on this project will be done by SS Stripping in Sterling Hgts. Talk to Chris, great guy and will give you a good deal!!!!!
ID:	34297   Click image for larger version
ID:	34302   Click image for larger version
ID:	34308   Click image for larger version
ID:	34309   Click image for larger version
ID:	34312   Click image for larger version
ID:	34313   Click image for larger version
TCP is offline   Reply With Quote
Old November 30th, 2008, 08:58 AM   #2
gmotox
gmotox's Avatar
Looking good!!! keep up the good work, looks like you have been making progress! keep posting pics on the build!!
Old November 30th, 2008, 10:42 AM   #3
TCP
Keep On Jeepin On
TCP's Avatar
Some more pics of the frame and axle I'm starting to work on.
ID:	34328   Click image for larger version
ID:	34329   Click image for larger version
ID:	34330   Click image for larger version
ID:	34331   Click image for larger version
ID:	34333   Click image for larger version
ID:	34334   Click image for larger version
Old May 12th, 2013, 10:50 PM   #4
TCP
Keep On Jeepin On
TCP's Avatar
It's been a while since i have posted anything, but I have done quite a bit on the project.
The following pics were taken after I did the following:
Front Axle - 4:88 gears, Eaton Elocker, WJ knuckles and brakes
1 ton steering - Chevy tie rod ends, 1 1/4 DOM tube
JKS disconnects
Addco sway bar
5 leaf Crown springs
Rocky Road Outfitters SOA kit
Rocky Road lift shackles
Rubicon Express bump stops
ID:	105873   Click image for larger version
ID:	105874   Click image for larger version
ID:	105875   Click image for larger version
ID:	105876   Click image for larger version
ID:	105878   Click image for larger version
ID:	105879   Click image for larger version
Old May 12th, 2013, 10:54 PM   #5
TCP
Keep On Jeepin On
TCP's Avatar
More pics
ID:	105881   Click image for larger version
ID:	105882   Click image for larger version
ID:	105883   Click image for larger version
ID:	105884   Click image for larger version
ID:	105886   Click image for larger version
ID:	105887   Click image for larger version
Old May 12th, 2013, 10:56 PM   #6
TCP
Keep On Jeepin On
TCP's Avatar
More
ID:	105890   Click image for larger version
ID:	105891   Click image for larger version
ID:	105892   Click image for larger version
ID:	105893   Click image for larger version
Old May 12th, 2013, 11:03 PM   #7
TCP
Keep On Jeepin On
TCP's Avatar
Decided to go with a 350. Used Advance Adaptors #713087. Here are some pics before cutting off the six cylinder mounts.
ID:	105897   Click image for larger version
ID:	105898   Click image for larger version
ID:	105899   Click image for larger version
ID:	105900   Click image for larger version
ID:	105902   Click image for larger version
ID:	105903   Click image for larger version
Old May 12th, 2013, 11:13 PM   #8
TCP
Keep On Jeepin On
TCP's Avatar
Engine came. It's a 355 tbi, full roller with vortec heads. I was told by the guy that built it he had one identicle to this dyno'd and it put out about 335 hp. Bought this as a crate engine from a guy in Texas. I got to pick what color I wanted it painted and what valve covers I wanted on it. Great price too.
ID:	105906   Click image for larger version
ID:	105907   Click image for larger version
ID:	105908   Click image for larger version
ID:	105909   Click image for larger version
Old May 12th, 2013, 11:19 PM   #9
TCP
Keep On Jeepin On
TCP's Avatar
Dropping it in!!!
ID:	105912   Click image for larger version
ID:	105913   Click image for larger version
ID:	105914   Click image for larger version
Old May 12th, 2013, 11:26 PM   #10
TCP
Keep On Jeepin On
TCP's Avatar
Put on the fly wheel and the Hedman headers.
ID:	105916   Click image for larger version
ID:	105917   Click image for larger version
Old May 12th, 2013, 11:36 PM   #11
TCP
Keep On Jeepin On
TCP's Avatar
Put on the GM serpentine belt kit #12497697.
ID:	105919   Click image for larger version
ID:	105920   Click image for larger version
ID:	105921   Click image for larger version
ID:	105923   Click image for larger version
Old May 12th, 2013, 11:46 PM   #12
TCP
Keep On Jeepin On
TCP's Avatar
Got a custom 46mm TBI unit from Sean at SPR Performance, tbiparts.com.
ID:	105925   Click image for larger version
ID:	105926   Click image for larger version
ID:	105927   Click image for larger version
ID:	105928   Click image for larger version
Old May 12th, 2013, 11:52 PM   #13
TCP
Keep On Jeepin On
TCP's Avatar
I have a lot more pics to add, but will do it tomorrow.
Old May 13th, 2013, 10:12 AM   #14
disturbedsledneck
disturbedsledneck's Avatar
Wow, very clean rebuild.
Pretty remarkable that you kept this project for nearly 5 years without selling it off as a whole or parts.
disturbedsledneck is offline   Reply With Quote
Old May 13th, 2013, 10:46 AM   #15
Wramblerguy
Wramblerguy's Avatar
X2 very nice/clean looking build
Are you going with an 8.8 in the rear?
3rd generation jeeper
Old May 13th, 2013, 06:04 PM   #16
TCP
Keep On Jeepin On
TCP's Avatar
Went with a Dana 44 out of a scout. It's actually all together and mounted. 4:88 gears, Eaton Elocker, Moser shafts, Wilwood disc brakes, and wheel spacers to bring it to size. Project is almost done I should have it on the road by end of summer, hopefully. Just now getting around to posting pics. I've wanted to do this project for a long time and I have so much money and sweat in to this project I don't think I will ever sell it.
Old May 13th, 2013, 06:24 PM   #17
TCP
Keep On Jeepin On
TCP's Avatar
Here are some pics of the rearend. Don't mind the bare spots. Needs a little touch up paint here and there.
ID:	105955   Click image for larger version
ID:	105956   Click image for larger version
ID:	105957   Click image for larger version
ID:	105958   Click image for larger version
Old May 13th, 2013, 06:42 PM   #18
TCP
Keep On Jeepin On
TCP's Avatar
Used a 700R4 rebuilt by a local trans shop. Had it rebuilt way overkill, Kevlar bands the whole shot. Transfer case is from JB Conversions. 231 HD with the super short SYE with GM VSS. Traction bar is a TB500 from M.O.R.E. CV driveshaft is from CCI in Marine City. Lokar shifter for the 700 and the transfer shifter is from Novak Conversions.
ID:	105960   Click image for larger version
ID:	105961   Click image for larger version
ID:	105962   Click image for larger version
ID:	105963   Click image for larger version
ID:	105965   Click image for larger version
ID:	105966   Click image for larger version
Old May 13th, 2013, 06:59 PM   #19
TCP
Keep On Jeepin On
TCP's Avatar
Durango steering gear box conversion. Pressure hose was made at The Parker Store in Fraser, about $40. Rough Country steering box brace. Stainless brake and fuel lines from Inline Tube in Shelby Twp. Used the YJ brake line kit they sell only made a few very small modifications. Fuel lines are just a bigger size to get fuel to the 355.
ID:	105969   Click image for larger version
ID:	105970   Click image for larger version
ID:	105971   Click image for larger version
ID:	105972   Click image for larger version
ID:	105974   Click image for larger version
ID:	105975   Click image for larger version
Old May 14th, 2013, 10:46 AM   #20
Wramblerguy
Sweet, even better I love it when someone does something different
Page generated in 0.33310 seconds with 84 queries
