broken nut help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 29th, 2008, 10:00 AM   #1
billywilly92
billywilly92's Avatar
Default broken nut help
Yesterday my dad was trying to remove the cab on my truck and the nut thats supposed to be welded on broke off so now the bolt and nut spin freely. We are thinking about cutting off the bolt but how to we get the nut welded back on there so we can put a new bolt in it?
Its the body mount behind the passenger door if that helps.
billywilly92 is offline   Reply With Quote
Old November 29th, 2008, 11:01 AM   #2
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
this happened to me on my YJ for the rear corner mount. I had to cut the steel out and weld in a new plate with a nut welded to that plate.
Old November 29th, 2008, 06:08 PM   #3
Yota Bill
pretty much all you can do, if there is no access to the nut from anywhere else...and make sure you use anti-sieze on reassembly...
Old November 29th, 2008, 08:40 PM   #4
billywilly92
I think I might be able to cut a whole in the cab and put the nut on then patch it back up
Page generated in 0.25463 seconds with 35 queries
