2002 Ranger wont engage into 4wd - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 25th, 2008, 08:56 PM   #1
72_K20
72_K20's Avatar
Default 2002 Ranger wont engage into 4wd
Thought it was the Transfer case motor, changed it out and still not going into 4x4 or even low range. Fuse in cab and the fuse under the hood are good. Anyone know if there is a way to bench check the motor? any suggestions on a fix, The only other thing I think it could be is the switch.
truck is an 02 ranger 4.0 4x4 with electronic 4x4
72_K20 is offline   Reply With Quote
Old November 25th, 2008, 09:03 PM   #2
Yota Bill
unbolt the motor, and manually turn the shaft for the case...if that works, then try the switch with the motor unbolted but still plugged in to see if the motor does/does not turn....
Page generated in 0.21761 seconds with 29 queries
