on board air - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 25th, 2008, 12:24 PM   #1
OL RED
workin hard to play hard
OL RED's Avatar
Send a message via Yahoo to OL RED
Default on board air
id like to run on board air in my truck with the factory a/c compressor. i know i need to but an inline oiler on it and run lines+tank. but does anyone know how to wire it so that it has a pressurized shut off? or where to get a pressure shut off system from.
OL RED is offline   Reply With Quote
Old November 25th, 2008, 12:40 PM   #2
Flexin' XJ
Flexin' XJ's Avatar
use a switch for an air compressor. that is what I did on my XJ. the one I bought also had a blow off line and I bought a check valve with a 1/4" compression fitting so when the compressor shut off it would purge the pressure from the line between the compressor and the check valve so the compressor would start easier.
I also ran a water/oil remover so the oil wouldn't get into my tank. The biggest problem here is finding one that can withstand the heat of an engine bay. The best one I could find only went to 175 degrees. And it was giant and expensive. Although XJ engine compartments get hotter than other vehicles.
I have pics from my XJ if you want them.
Flexin' XJ is offline   Reply With Quote
Old November 25th, 2008, 01:07 PM   #3
OL RED
OL RED's Avatar
whered you get the switch from?
Old November 25th, 2008, 01:41 PM   #4
Flexin' XJ
Flexin' XJ's Avatar
you have a pm
Old November 25th, 2008, 09:16 PM   #5
Sandals
Fucking Zen as Shit
Sandals's Avatar
grainger = cheap
Page generated in 0.22692 seconds with 38 queries
