Transfer Case Clunk - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 24th, 2008, 04:55 PM   #1
RUSTYSPIKE9
RUSTYSPIKE9's Avatar
Default Transfer Case Clunk
When 4X4 is engaged it clunks. It is a light cluck. It did this a little last year but once I used it more it went away and didn't do it again. When I disengage 4X4 it doesn't seem to let go. It clunks a little more for a while. If I go in reverse it seems to disengage quicker. I think the sound most sounds like a noise a drive shaft would make if it were cliping the frame when rotating...if that helps.
RUSTYSPIKE9 is offline   Reply With Quote
Old November 28th, 2008, 12:35 PM   #2
RUSTYSPIKE9
Any suggestions
Old November 28th, 2008, 01:57 PM   #3
Captain Ledd
Ranger Addiction?
Captain Ledd's Avatar
year? Ranger? F150? F250? Manual/Automatic tranny? Manual/electric T-case?
Old November 28th, 2008, 02:08 PM   #4
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
if your fighting the case letting go of being engaged. it sounds like you have a tire or gear ratio issue. when ever you have a bind it has to be winding up the suspension like a spring to get in a bind like that
Yetti
Old November 28th, 2008, 03:31 PM   #5
Captain Ledd
Ranger Addiction?
I ask because the Rangers electric shift motor causes similar issues from, strangely enough, not engaging/disengaging things all the way. Rather finicky motor assembly and it's not well sealed.
Old November 29th, 2008, 10:18 AM   #6
RUSTYSPIKE9
Truck is a 98 F250. Auto tranny. Electric T-Case. I don't think it is a binding noise. It is on a rotation that it clunks/clicking kinda noise.
Page generated in 0.25129 seconds with 42 queries
