E4OD Shift help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 24th, 2008, 08:32 AM   #1
Default E4OD Shift help
have a 92 F250 with an E4OD, supposely rebuilt earlier this year. My 1-2 shift is pretty harsh. Almost like an aggressive shift kit was installed. Seems to hold 1st gear to long when driving through towns etc. I do not see any adjustments being no kickdown cables etc... the other shifts feel okay, just the 1-2 shift
anybody got any advise or thoughts?
Old November 24th, 2008, 08:37 AM   #2
Tom
Because racecar
Tom's Avatar
You need to scan it, see if you can pull any codes. It could be a problem with the trans range switch (MLPS) or a bad rear wheel speed sensor, or a bad solenoid pack.
Old November 24th, 2008, 10:10 AM   #3
i didn't get any tranny codes, one lean o2 code and a below min voltage on the egr with KOER
Old November 24th, 2008, 02:24 PM   #4
i haven't had a chance to bring it in yet, but i have a MLPS on its way from ford for $30.....I'll just throw it in and see what happens. The truck has 210K on it.
Old November 24th, 2008, 02:39 PM   #5
Tom
Because racecar
Tom's Avatar
Also take a good look at the connector, make sure it isn't green either (they are notorious for that)
Old November 24th, 2008, 05:14 PM   #6
no IGS in the connector.....but now it shifts so smooth i almost can't even feel it at the 1-2
Page generated in 0.20818 seconds with 41 queries
