1992 YJ Trade for extended cab pickup - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 24th, 2008, 04:31 AM   #1
ejnovinsky
Default 1992 YJ Trade for extended cab pickup
Ill trade this for an extended cab pickup, or 3000 firm, heres the details.1992 Jeep Wrangler YJ
4 liter inline 6 cylinder
5 manual ax 15 transmission
175,xxx miles
Runs and shifts great!
The good:
new battery and cables
new rear brakes (one side is done...have parts for other, just havent gotten to it yet)
posi lock (replaces vacuum motor for 4WD)
3 inch body lift
31 inch wrangler tires w/ decent tread full size spare is brand new
hard top
full hard doors
typical jeep rust, but not bad...frame is solid
brush guard (homemade)
Hella off road lights
cobra CB w/ whip antenna
interior is coated in truck bed liner (still have carpet as well)
homemade swing out spare carrier
diamond plate rocker covers
Sony CD player
The bad:
has a small rear main seal leak........
just loses a few drops, could be left alone
if you dont mind a few oil drips in your driveway every morning
rear main is a very expensive job to have fixed in a shop, but if youre
a decent mechanic could be fixed in a weekend very cheaply, but a
very time consuming fix, and not for an amateur...
The indifferent:
could use shocks and exhaust, but both are fine as is
brake dash light is on for some reason (will try to bleed when I do other rear, that may solve it, or may just need battery discoed to reset)
Reply here or call 419 308 4330, ask for Ethan
Thanks!
ID:	34003   Click image for larger version
ID:	34004   Click image for larger version
ID:	34005   Click image for larger version
ejnovinsky is offline   Reply With Quote
Page generated in 0.22830 seconds with 27 queries
