A Stupid Newbie Queston - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > 4x4 Talk > Jeep Tech > Jeep tech FAQ
Jeep tech FAQ Look here first!
Old November 23rd, 2008, 07:13 PM   #1
SirSavage
SirSavage's Avatar
Question A Stupid Newbie Queston
So I need to know if I can just buy and install the 2" spacers to lift my 98 wrangler, or if I have to do a whole bunch of other work with other parts as well. If that's the case I might not lift it.
Thanks
SirSavage is offline   Reply With Quote
Old November 23rd, 2008, 07:15 PM   #2
Sandals
Fucking Zen as Shit
Sandals's Avatar
you will also need shocks, unless your not taking it offroad, and just driving on road
Old November 23rd, 2008, 07:18 PM   #3
xjmichigan
xjmichigan's Avatar
Good edit CC, that would depend if you are talking about a 2" spacer body lift or a 2" spring spacer lift.
Old November 24th, 2008, 02:23 AM   #4
SirSavage
SirSavage's Avatar
Okay so which would you recomend;
This,
http://www.savannajones.com/products...08%2C16117+109
Or this,
http://www.4wheelerssupply.com/catal.../products_id/1
Old November 25th, 2008, 01:17 PM   #5
JEEPR
Playing Possum
JEEPR's Avatar
the first one is what you will need (and an alignment), the second one is just the spacers with no shocks or anything. Spacers are spacers, as far as I know, there is not much difference between them. The shocks are what make the ride. Get the cheapest spacers you can find, and the best shocks you can afford.
JEEPR is offline   Reply With Quote
Old November 25th, 2008, 11:06 PM   #6
SirSavage
SirSavage's Avatar
Well thanks, I'll start looking into it
Old November 30th, 2008, 04:53 PM   #7
SirSavage
SirSavage's Avatar
So I'm wondering are shocks adjustable because I've got 'Rancho rs 5000' on my jeep now.
If I can keep them with a 2" spacer lift kit that would be cool
Thanks
Old December 1st, 2008, 09:11 PM   #8
Bishop
Bishop's Avatar
^ no well not for what you need.
you dont need them. you would just lose 2" of down travel.
so if you wold really like to jack jeep up by axle put jack stands on frame. lower axle. mesure how far youre axle drops and take away 2" from that. and if you will be ok with that # then run the same shocks. if not buy ones 2" longer for stock down travel
Old December 2nd, 2008, 11:13 AM   #9
muddy maki
Its tough out there.
muddy maki's Avatar
Send a message via AIM to muddy maki
yes you can keep your shocks. realy wont hurt much. i run a 2" lift like the one you listed and have had stock shocks in the back for years. BUT wrifrocks is corect you will lose 2" down travel.
my sudjestion is if you want to keep your shocks install these
http://www.teraflexplus.com/shop/pro...roducts_id=221
http://www.teraflexplus.com/shop/pro...roducts_id=220
with these installed you will only lose 1" of down travel!
then when it is time to replace your shocks buy 4 rear shocks and install this up front.
http://www.teraflexplus.com/shop/pro...products_id=87
you will then have corect down travel in the front, and only lose only 1" down travel in the back
Thats the rout i would go
actualy i kinda did. just need another set of rear shocks for the front.
muddy maki is offline   Reply With Quote
Page generated in 0.32475 seconds with 50 queries
