545RFE or 45RFE Shift Kit - Dodge Hemi Truck, Durango, Etc - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 22nd, 2008, 08:03 PM   #1
Rider 414
!CLUTCH!
Rider 414's Avatar
Default 545RFE or 45RFE Shift Kit - Dodge Hemi Truck, Durango, Etc
Hey,
I thought I'd share my thoughts of a shift kit I installed on my Hemi TJ that has the 5 speed auto. This tranny is behind most hemi trucks and durangos.
The stock tranny is smooooth and nice, otherwise mushy!! I wanted my tranny to have firmer shifts and to hold the gears alittle longer on heavy acceleration. I installed a Transgo 545RFE-HD2 kit today. It was suppose to do just that.
After the install the trans is alot firmer and shifts much faster. For the $70.00 kit I would say that its a great deal for what you get. A much improved tranny if thats your thing.
I would say wait until your going to do a tranny oil change. Its not worth wasting clean tranny oil doing the installation. I was bored and I did it anyway. I was able to recover most of the oil. It was super easy to install. Took me about 1 hour.
Before when accelerating, the auto would shift early and slow. Now its fast and firm. 3rd to 4th is also way better and holds the gear longer. My TJ is really really fun to drive around and now its much better.
Rider 414 is offline   Reply With Quote
Old November 22nd, 2008, 09:32 PM   #2
NightKrawler
KOH Jackhammer
NightKrawler's Avatar
Sounds like a good idea.
Any more pics of your jeep with the hemi?
Subscribe for more videos http://www.youtube.com/user/bult4mud/videos
http://www.youtube.com/channel/UCYL4kHv0JB5sOKlPALLHGTQ
--l ,[____],
l---L 0lllllll0-
()_) ()_)--o-)_) .......
NightKrawler is offline   Reply With Quote
Old November 25th, 2008, 06:23 AM   #3
nickb304
nickb304's Avatar
carfull with those hard 3 to 4 or hard downshifts into second prime. The drag strip guys over on dodgetalk have a hell of a time keeping those trans togeather even when built up if they don't lock out the overdives when running them. pushing a little jeep around probably will not be nearly as hard on it though. Stock motor?
nickb304 is offline   Reply With Quote
Old November 25th, 2008, 08:08 PM   #4
Rider 414
!CLUTCH!
Rider 414's Avatar
Really? Hmmm I am definatly not on the strip running it. The motor is mild compared to the hemi guys really doing alot. Ive got a big cam and springs, computer tune, CAI, free flow exhaust, stall converter, and some other little bits. Im about 400 HP compared to the 345 of a stock Hemi.
Old November 26th, 2008, 10:34 AM   #5
nickb304
nickb304's Avatar
overall the trans is pretty stout. I guess the problem is the overdive clutches are weak compared to 1st-3rd and don't hold up to repeated wot shifts. The 2nd prime passing gear also works off those clutches. that causes the most problem from what i hear. say your rolling along at 55-60mph and you jump on the throttle hard, it will downshift under full power into that gear that is normally not used that runs of the overdive clutches. it will eventually burn up those clutches. i don't think you will have a problem running around in a little jeep offroad. just letting you know it was one of the minor issues with that trans that i ran across when doing reserch before buying my new hemi ram. i had all kinds of trouble with my old dodge 46re trans so i looked into it before buying the new truck.
Old November 26th, 2008, 11:24 AM   #6
greygoose
I'm the dude
greygoose's Avatar
Hmmm.... Good to know, I was thinking of getting this kit eventually for my Jeep....
Old November 26th, 2008, 11:06 PM   #7
dline
dline's Avatar
what cam do you have?
dline is offline   Reply With Quote
Old November 27th, 2008, 09:38 AM   #8
Rider 414
!CLUTCH!
Rider 414's Avatar
Comp Cam XFI 273 -
Bascially the biggest cam Comp Cam has for the 5.7
Lowend is about the same as stock, but mid-to-top end is insane. Also the idle is lumpy and sounds awesome. Definalty need a computer tune and new valve springs. Im running Manely beehive style springs. This motor loves to rev!!
Running around the street, I stay out of wot because its so violent. The acceleration and torque at lower speeds overwelms the soft springs in the suspension. Its a handfull but super fun.
Old November 27th, 2008, 09:42 AM   #9
Rider 414
!CLUTCH!
Rider 414's Avatar
Old November 27th, 2008, 01:07 PM   #10
dline
dline's Avatar
i am getting a 6.1 stroker built for my ram and i am gonna use the comp 273.
did you paint the block orange?
no piston to valve clearance issues with stock heads?
Old November 27th, 2008, 01:48 PM   #11
Rider 414
!CLUTCH!
Rider 414's Avatar
Yes - has to be Hemi Orange.
No valve clearance issues - have about 1000 miles on the cam now and a few high rpm romps with no issues. I like the cam - ALOT.
Old November 27th, 2008, 01:59 PM   #12
Rider 414
!CLUTCH!
Rider 414's Avatar
Hey!! So your doing a SRT 6.1 crank and pistons? Who is doing your computer work? I am really curious - also are you doing anything with the heads? What intake are you running?
Old November 27th, 2008, 01:59 PM   #13
dline
dline's Avatar
cool should work good for me, 3000 stall converter, 4.56 gears, and lots of torque from the stroker will get me going, and 6600 rpm rev limiter for now
jm 5.7 cylinder heads
6.1 callies crank, i have a 6.1 aluminum oem intake manifold waiting to go on. i've been using a pretty good cold air intake for now with the plastic oem 5.7 intake
do you have a ram computer in there?
Old November 27th, 2008, 03:32 PM   #14
Rider 414
!CLUTCH!
Rider 414's Avatar
I have a 04 ram computer that was tuned by BG Chrysler in Warren. The guy over there is a complete dick bag and I have some wierd things going on here and there. That's why I was wondering who was going to do your computer?
Old November 28th, 2008, 06:36 PM   #15
dline
dline's Avatar
sct can tune your computer
Page generated in 0.34408 seconds with 68 queries
