Duplicolor bed liner not so good, rustoleum?? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 21st, 2008, 08:20 PM   #1
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Default Duplicolor bed liner not so good, rustoleum??
I bought a qt of the Duplicolor bed liner the other day for $18. I applied it after sanding the entire area of the back of the YJ tub with 60grit sandpaper. Well I go out the next day and there are areas where it has bubbled and scraps away very easily.
I have always just rustoleum on the entire floor and has never let me down. When it starts to wear away on the driver side floor pan I just recoat it.
Question is for those that use this, do you apply the rustoleum primer first? Or just rustoleum the painted/bare metal?
Old November 21st, 2008, 08:26 PM   #2
clint357
Web Wheeler Extraordinair
clint357's Avatar
I have the duplicolor spray-on bed liner on my bumper and rockers and never had a problem. I know it will flake if you do mulitple coats more than 10 minutes apart. I don't know if the temp plays a part in this though. Another thing is that it takes about 2 weeks to fully cure, but then it's tough as hell.
clint357 is offline   Reply With Quote
Old November 21st, 2008, 08:30 PM   #3
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
it seems like the stuff you buy in the can is different than the qt. For one you don't get that nice texture.... I used a brush so you see the lines (which I don't care about).
I sprayed my bumper with the spray and it does OK.
Old November 21st, 2008, 08:37 PM   #4
DCX
out to lunch
DCX's Avatar
So you applyed the duplicolor on bed liner over a surface you had painted with rustoleum?
DCX is offline   Reply With Quote
Old November 21st, 2008, 08:41 PM   #5
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
I sanded it all down...
Old November 21st, 2008, 08:49 PM   #6
DCX
out to lunch
DCX's Avatar
If there was any of the rustoleum left that is most likely what caused the duplicolor bed liner to act like that. Lacqure over enamel thing.
Old November 21st, 2008, 08:53 PM   #7
NSmist
NSmist's Avatar
Send a message via AIM to NSmist
Don't have a lot of experience with bed liner in a can, but possibly look at getting a thing of wax and degrease and finish with a tack cloth. Just thinking with painting cars...would a silicone product such as Armor All irritate bed liner? I've seen that happen once or twice while in the spray booth.
NSmist is offline   Reply With Quote
Old November 21st, 2008, 09:00 PM   #8
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
I used a wax/grease remover. The areas where it seemed to bubble was on regular paint, which was under the rustoleum. Regular paint being automotive paint.
I really don't know why I used the bed liner as nothing is going to be placed in the rear, and I run the rear bench seat. I'll have my fuel cell taking up all the trunk space.
I'm just pissed about my $20 lol. I do have a little less than 1/2 qt left.
Old November 21st, 2008, 09:29 PM   #9
bacongrease
Am i still a Noob?
bacongrease's Avatar
use the duplicolor over top of my rustoleum and vice versa, never seen an effect,
the roll on duplicolor usually takes more than 2 days to cure, it will be dry to touch after about a 12hours or so. i did the whole interior and could smell it curing for almost a week.
bacongrease is offline   Reply With Quote
Old November 21st, 2008, 09:34 PM   #10
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Yeah i went to the garage and it seems like its better.
Old August 21st, 2009, 06:16 AM   #11
A4X4SPIT
A4X4SPIT's Avatar
Ive had a similar issues with duplicolor in the gallon can Inomatter how good the prep. we never painted anything over rustoleum except rustoleum something about it used to be fish oil based Idont know itf thsats the case any more
A4X4SPIT is offline   Reply With Quote
Old August 21st, 2009, 07:36 AM   #12
sanman
sanman's Avatar
i used the duplicolor and applied it with a roller on my tj, i did the hood and it was on there a couple of year's and started to bubble. just redid it again and sprayed clear coat over it this time.
sanman is offline   Reply With Quote
Old August 21st, 2009, 08:50 AM   #13
TomH
Oftentimes an idiot
TomH's Avatar
Originally Posted by rd6.new View Post
I have qwikliner spray on bedliner and it works well.
This coming from a Qwikliner dealer.
TomH is offline   Reply With Quote
Old August 21st, 2009, 08:56 AM   #14
89Jeepy
89Jeepy's Avatar
x2 anything under that stuff causes it to bubble up and and not adhere right. It will pull any paint right off with it. Which is good for when you have to redo it. learned from personal experience...
89Jeepy is offline   Reply With Quote
Old August 21st, 2009, 09:00 AM   #15
blownexploder94
Todd
blownexploder94's Avatar
rustoleum has bedliner in a spray can to now, works pretty well. i saw someone spray the rockers on his truck all he did was wipe the it down with paper towel and has been on there for a few months and looks pretty good. im surprised it didnt come off since it was not prepped
Old October 26th, 2009, 11:36 PM   #16
VinnyMartello
Talking A way to get better Results from Rustoleum Bed Liner
Here's a little trick (more like great undertaking) That seems to make the Rustoleum Bed Liner stick pretty good. I did this to the Channel Frame of my Ford F-150. Use something like a DeWalt grinder with 36 grit sander wheel and strip that dogone rust down to mostly bare metal! Spray on a good even coat of Rustoleum Rust Reformer Primer. (This stuff is better than most Rustoleum stuff). Let it fry for a day or two. Them git yerself a nice big bucket of nasty smelling Truck Bed Liner. It claims to kill children in their sleep so it has to be good! Then, slather that stuff on with a good brush in an even coat. Then do a slight recoat about two hours later. I did this t0 the frame and all of the new leaf spring hangers and shackles and coil spring brackets when Dad and I rebuilt the whole Chassis on our 95' F-150. It seems to stick good and the finish is presentable, but not show quality (does in need to be?). It has decent durability for just a thin coat. I have yet to see how it holds up in the long haul that that time consuming method works good. If you really clean that metal and prime it, thats what does the magic. Please folks... dont be like the guys in their Honda Civics that paint over dirt!!! Have a good one!
-Vinny
VinnyMartello is offline   Reply With Quote
Old October 27th, 2009, 01:41 AM   #17
littleXJ
littleXJ's Avatar
i rolled it on my xj, never had a problem. my buddy used the spray can stuff on the under side of his WS6, and my other buddy got a qt and brushed it on in his wheel wells on his gto. all with great results. all in the prep, make sure there is NO rust or eles it wont bond to the surface.
EDIT; this was all the duplicolor stuff.
littleXJ is offline   Reply With Quote
Page generated in 0.45771 seconds with 74 queries
