XJ with NO heat... any ideas? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 21st, 2008, 08:42 AM   #1
el fin del mundo
Default XJ with NO heat... any ideas?
2001, blower on, knob cranked into the red, NO heat! WIfe is pissed, especially this morning. Stuck thermo? Thanks in advance...
el fin del mundo is offline   Reply With Quote
Old November 21st, 2008, 08:56 AM   #2
MidMichxj
Wrenchin for a livin
MidMichxj's Avatar
Check coolant level.
Check heater hoses w/engine @ operating temp..
Are they both hot?
If they arre it is a door/control problem.
If they are not it is a fluid flow problem (low coolant level/low coolant temp./ restricted heater core).
I hope this helps.
MidMichxj is offline   Reply With Quote
Old November 21st, 2008, 08:58 AM   #3
Bones
Bones's Avatar
is there a temp gauge on the dash? Does it stay on cold, or move up to a normal operating area?
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old November 21st, 2008, 09:07 AM   #4
jeepxj_boy_21
linked
jeepxj_boy_21's Avatar
x2 this the one you were talking about picking up the other day?
jeepxj_boy_21 is offline   Reply With Quote
Old November 21st, 2008, 11:50 AM   #5
el fin del mundo
Yeh, I picked it up and... NO heat. It is Nice, I think I like it more than my black one. I might keep it... I will show you the pics when I come over.
Old November 21st, 2008, 11:52 AM   #6
el fin del mundo
I will check all of the suggestions. It only has 45000 on her. I bought it to sell, it came fromTexas. So, I want to fix the odds and ends and post in on Auto Trader. Thanks for the info, all of you...
Old November 21st, 2008, 01:07 PM   #7
Bones
Bones's Avatar
I would defenetly think Tstat then... It could have been stuck open for years down there and no onewould have really noticed... they might have even pulled it completely.
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old November 21st, 2008, 01:44 PM   #8
jeepxj_boy_21
linked
ok sounds good
Old November 22nd, 2008, 07:18 AM   #9
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
check coolant level first. low coolant will make it not have heat and would also cause overheating if low enough. one main concern i'd have is a cracked head. seen a few 4.0's with cracked heads or blown head gaskets. not a bad enough leak to cause it to run like crap but the engine would pump air into the coolant and force it out of the overflow. heater core is pretty high in the system so thats where the air would go in the system.
Page generated in 0.30563 seconds with 50 queries
