D44 Detriot locker SOLD - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 20th, 2008, 08:09 AM   #1
Default D44 Detriot locker SOLD
Pulled it from a waggy axle. Had 4.88 gears installed on it, but the gears do not come with it unless purchased seperate. I dissassembled the locker due to the fact i never drove the truck. All interenals looked good and showed very little wear if any at all. Has one carrier side bearing on it and the other one is removed. When i dissassembled the axle, it had a broken shaft. It chewed a little of the metal around the entrance to the lcoker where the shaft slides in. The spline engagement was not hurt and the area was cleaned with emery cloth to smooth out. No functional damage was done to the locker. I would use it myself if my truck wasn's already locked front and rear.
$300 obo
Middleville/ Grand RApids
CheapThrillB2 is offline
Old November 20th, 2008, 08:32 AM   #2
el fin del mundo
PM me about this Diff. I want it...
el fin del mundo is offline
Old November 20th, 2008, 08:39 AM   #3
pm sent
Old November 20th, 2008, 08:57 AM   #4
this is the spot i was refering to, i smoothed it out with emery cloth and the egg out of roundness to the inner hole only goes about 1/8" or less into the bore. NO damage to the outer surface the bearing presses onto.
Page generated in 0.17711 seconds with 35 queries
