302 carb probs - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 21st, 2008, 02:59 AM   #21
bigblockford79
Big Block Ranger
bigblockford79's Avatar
Originally Posted by YJREMIX View Post
both squirt good. I will check the filters. If the angle is the prob, what can I do to fix it? I am obviously not a carb guy but i can turn wrenches
To fix the angle you could either raise the float level a little to comensate for the difference or look for a carb spacer that has a tilt to it. Like this one http://www.allstarperformance.com/sp...ts/pdf/724.pdf
The description for problem this spacer corrects pretty much sounds like the problem you are having. There are also many others out there for around $40-50.
If you want I may be able to customize one or even make one for you if you like.
Old November 22nd, 2008, 07:16 PM   #22
YJREMIX
stay classy waterford
YJREMIX's Avatar
That would be sweet, How much? And thanx for all the good info everyone!!!
YJREMIX is offline   Reply With Quote
Old November 23rd, 2008, 06:15 AM   #23
bigblockford79
Big Block Ranger
Price depends on what you want it made out of. About $25 for aluminum. But I need to know what the angle is. It will take about 2-3 weeks to get to it also.
Old November 23rd, 2008, 04:44 PM   #24
YJREMIX
YJREMIX's Avatar
I will work on finding the angle.
Page generated in 0.32494 seconds with 35 queries
