would a zr2 lift fit a 4x4 s10??? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 19th, 2008, 12:37 PM   #1
SavageWarriorx87
Back Country Mudder!
SavageWarriorx87's Avatar
Send a message via AIM to SavageWarriorx87
Default would a zr2 lift fit a 4x4 s10???
i have a 2000 chevy s10 4x4 and i want to do a zr2 lift on my truck i wanted to know if it will fit and what a z2r lift consistis of i know bigger leaf spring but whats in the front just torsion keys or drop down brackets!! Let me know if any one know what i should do!! thanks Ryan
PM if you want to tell me something!!
SavageWarriorx87 is offline   Reply With Quote
Old November 19th, 2008, 01:11 PM   #2
Grunto
Grunto's Avatar
Send a message via AIM to Grunto
It depends on how big of a lift...
Are you talking about making a non-ZR2 sit like a ZR2? I don't think ZR2 leaf springs are actually any bigger than a regular S10 leaf, I'm pretty sure it just has to do with where the mounts are located. I'm pretty sure that is the main difference in general, the location that suspension stuff mounts to the frame. The A arms might be longer in the front too, I really don't know for sure though.
Here is a good page to look at if you don't know what kind of lift to get.
http://www.s10forum.com/forum/f222/4...t-kits-272896/
Hope I helped
(This should probably also be in Chevy Tech)
Grunto is offline   Reply With Quote
Old November 22nd, 2008, 01:31 AM   #3
busyfixin
Balls Deep
busyfixin's Avatar
i remember there being a frame width difference as well, but they may just have been the 94-95 trucks.
Old November 22nd, 2008, 07:13 AM   #4
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
there is a diffrence between ZR2 and non Zr2 trucks. thats y when you look at lift kits for the 2 they list them as seperate part numbers meaning there diffrent kits.
Old November 22nd, 2008, 09:56 AM   #5
beedle4
beedle4's Avatar
Correct the frame geometry is diff. The Z achives its lift from lower mounting points for the suspension and also is slighty wider. So no you will need to find a reg S-series lift for your truck!
Old November 22nd, 2008, 09:59 AM   #6
beedle4
beedle4's Avatar
A 5" or 6" suspension lift runs around $2,000 new. Depending on what you have to spendyou can start with a 2" body lift for around 200 or a 3" for a 94 s-10 will fit also except for the rear bumper brackets but you could fab those up eazy and it runs around 160. Or if ya got lots of cash go for a solid axle HP dana 44!
Page generated in 0.26858 seconds with 41 queries
