inline 6 issuses - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 19th, 2008, 10:05 AM   #1
socket17
Default inline 6 issuses
Im currently having a problem with my 1988 f150 with the 4.9 inline 6
The truck will miss only in gears R and D under load and only after 1500 rpm. if your in neutral you can hit a easy 4,000 rpms
Ive replaced the coolant temp sensor and checked the TPS EGR IAT sensors but still cant figure it out. Ive also checked the TFI senors.
Let me know what you think. i would like to keep the motor because it only has 90k miles on it but if i have to i may do a swap to somthing bigger.
socket17 is offline   Reply With Quote
Old November 19th, 2008, 02:55 PM   #2
chris1044
chris1044's Avatar
plugs/wires arcing when the engine is under a high load (hence the reason it doesn't miss in N/P)
Take a spray bottle and mist the wires/distributor/plugs down - chances are you'll see the spark arcing where it's not supposed to. If you don't, the next step would be to pull the distributor cap and check for carbon tracking....
Old November 19th, 2008, 02:57 PM   #3
IDIeselman
IDIeselman's Avatar
+1 Sounds like the plugs are breaking down under a load. New plug/wires are in order.
Old November 19th, 2008, 03:02 PM   #4
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
x2
Plugs, wires, rotor, and cap are relatively cheap nowadays. If they've never been done, just throw those on.
Old November 19th, 2008, 03:15 PM   #5
Bones
Bones's Avatar
a lack of fuel will also cause a miss under load
replace fuel filter
check fuel pressure in D under load
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old November 19th, 2008, 03:21 PM   #6
Bishop
Bishop's Avatar
replace fuel filter
to add to that either presure or flow.
you can have good presure readings but not enough fuel flowing.
so if you still have a problem with good presure be sure to check for good flow.
Old November 19th, 2008, 05:01 PM   #7
socket17
plugs wires cap and rotor are new.. fuel pump is new both of them. in the tank and in the frame rail.
it did this about 500 miles ago and i let it sit for a month while i redid the brakes lines and when i took it out to test the brakes it didnt miss.. started up again on saturday night.
to get the truck home from big rapids i dropped it in neutral going about 25-30 mph and reved it up to around 4k rpm (figureing it would either blow or go) then shut it off and coasted to a stop when i restarted the truck i was able to get to 45-50 mph or 2-2300 rpms but no more then that.
coil is new too.
Old November 19th, 2008, 07:47 PM   #8
jontboudrie
jontboudrie's Avatar
Default engine problems
change the plugs you have a bad one. happened to me before
jontboudrie is offline   Reply With Quote
Old November 19th, 2008, 08:02 PM   #9
IDIeselman
IDIeselman's Avatar
Yup, Before the tach it out and shut it off episode I would guess it would hold cruising speed fine on the flat but once you hit the gas it would start cutting out, Just because the plugs are new don't mean they are good. When you done that you just made the bad plugs worse by loading them up with fuel and shutting the engine down.
Old November 19th, 2008, 09:03 PM   #10
DeRanged mudder
completly insane
DeRanged mudder's Avatar
Send a message via Yahoo to DeRanged mudder
coil is new too.
What about the filter? The filter could easily be the problem.
DeRanged mudder is offline   Reply With Quote
Old November 19th, 2008, 09:14 PM   #11
socket17
no it wouldnt hold cruising speed at all 25mph if that but your right on the hill part. im gonna pick up another set of plugs tomorow and try that.. didnt figure the plugs would be bad after only 2k miles on them.
Old November 19th, 2008, 09:15 PM   #12
socket17
filter is new and when i changed the pumps i drained and cleaned out the tank. wiped it out by hand..
the truck sat for a few years with out moving.
Old November 19th, 2008, 09:25 PM   #13
DeRanged mudder
completly insane
TFI module? distributor pick up?
Old November 20th, 2008, 04:41 AM   #14
Bishop
Bishop's Avatar
i assume it is a carbed motor. have you looked at a rebuild at all?
or depends on the carb but there may be a screen at the fuel inlet, if it is real dirty you could have particles that are pluging up the carb.
Old November 20th, 2008, 06:33 AM   #15
fsumotorhead
N8KVB
fsumotorhead's Avatar
Does it does this all the time or intermittenly (sp), could also be moisture in the cap, spray/soak it all in wd-40 and take it for a drive. I've had small cracks in caps that would cause this on humid or rainy days.
just another idea
Old November 20th, 2008, 10:13 AM   #16
socket17
no i wish.. its fuel injection.
Old November 20th, 2008, 10:23 AM   #17
Bishop
Bishop's Avatar
look at the cat at all. I have seen a few that do this when its pluged.
Old November 20th, 2008, 12:25 PM   #18
socket17
cats are gone already. first thing i checked.. they where both good..
Old November 20th, 2008, 03:44 PM   #19
Bishop
Bishop's Avatar
well thats all i got. Good luck
Old November 20th, 2008, 08:12 PM   #20
Jdc215
Jdc215's Avatar
if its fuel injected it may be the fuel pressure regulator or a bad vacume tube attached to it or bad/dirty fuel injectors.
i had a similar problem on my 2.9, turned out to be a combination of ignition components, the fuel pressure regulator and a bottle of lucas fuel system cleaner. that combination cleared it all up
Jdc215 is offline   Reply With Quote
Page generated in 0.32973 seconds with 83 queries
