"Dirthead 509" TJ Project - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 29th, 2008, 07:36 AM   #21
KennyOffroad
Ridge Runners Offroad
KennyOffroad's Avatar
Nice.
Old December 1st, 2008, 02:18 PM   #22
Set engine back in, clocked D300 6 deg down from flat to almost clear the tunnel. Have to either put 1" body lift in or cut some sheet metal. Not sure if I'm going to end up running a doubler yet so I don't want to cut sheet metal twice. 1" body lift(doh) it is I guess. Really didn't want to but don't really see a way around it right now.
Old December 1st, 2008, 02:27 PM   #23
GOTRCKS
"RHINO ZJ"
GOTRCKS's Avatar
Looks like you have your hands full either way.
Nice build up. Can't wait to see it finished.
GOTRCKS is offline   Reply With Quote
Old December 1st, 2008, 02:48 PM   #24
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
Body lifts are nice for working on things. You will like it.
Old December 1st, 2008, 09:10 PM   #25
xj4life
xj4life's Avatar
i'd go body lift for now. like you said you dont want to cut twice.
how would that affect the tube work though? seems like you wouldnt ever be able to get rid of the body lift if you built the tube work with the lift on.
Old December 3rd, 2008, 07:57 AM   #26
KennyOffroad
Any Pics ?
Old December 3rd, 2008, 08:50 AM   #27
Good point, I'll probably end up with a 1" body lift from here on out. I'm ok with trading a 1" body lift for a flat belly twin stick . I need to put a list together and get parts ordered for christmas shutdown.
Old December 27th, 2008, 04:06 PM   #28
1" body lift installed. Hacked crossmember won't work with a D300 without going to more than a 1" body lift(not acceptable, don't like body lifts at all). Going to have to make it out of tube. Had water in the house today, 12 hr day that was dedicated to working on a TJ spent drying my house out.....what a waste.
Old December 27th, 2008, 05:13 PM   #29
Nightdr
Default nice
hey great work keep it up...
Nightdr is offline   Reply With Quote
Old December 27th, 2008, 05:38 PM   #30
Items ordered last week:
I have 7 Currie 1.25" LH threaded JJ's on order from Ironman Offroad, thanks Pat. (www.ironmanoffroad.com)
7 Threaded inserts (http://www.trail-gear.com/links.html)
20' of 2" x .25"wall DOM (thanks Ricky)
20' of 1.75" x .120" wall DOM (thanks Ricky)
12 Chevy poly bushings with 1.5" minor OD (thanks for the info H a g g a r)
1 stock 4.0L TJ tranny mount
Old December 30th, 2008, 04:46 PM   #31
Some bling showed up today
Old December 30th, 2008, 04:49 PM   #32
Rear suspension I'm planning on running.
Old January 3rd, 2009, 12:11 AM   #33
14hrs today.....I'm tired and sore. Had to make up for yesterday
Crossmember in, need to finish welding and paint
Had to do some "custom" work to the floor with a BFH to get enough clearnace to put the D300 flush with the bottom of the frame rail. Very concerned with front driveshaft clearance issues.
Removed front and rear stock axles, put jeep at ride height. Cut brackets and cleaned the frame up.
Brackets:
No Brackets
Removed this from above the gas tank prior to grinding.....that would have been great, fire right on top of the gas tank.
Also removed the brackets from the 14B today. Tomorrow I need to drop the gas tank and start making brackets for the 4 link.
Old January 3rd, 2009, 12:26 AM   #34
s.hembree
s.hembree's Avatar
That's all you got done it 14 fawkin hours? WTF else did you do for 12+ hours of the day? I'm rather disappointed.
Old January 3rd, 2009, 08:38 AM   #35
All my help went south
Old January 5th, 2009, 08:31 PM   #36
its the 5th, wheres the last two days of work......
Old January 5th, 2009, 08:38 PM   #37
Cut steel for brackets tonight. I have to return the plasma cutter Sunday so I need to get everything that I'm planning on using the plasma cutter on done......including link brackets. Designing rear truss as we speak
Old January 5th, 2009, 08:49 PM   #38
nd4spd71
nd4spd71's Avatar
I think the xj will out wheel it.
nd4spd71 is offline   Reply With Quote
Old January 5th, 2009, 08:55 PM   #39
Buy it and find out
Old January 6th, 2009, 11:31 AM   #40
two_much_talk
sit down shut up and ...
two_much_talk's Avatar
I remember the day I cut off the stock TJ brackets! Alleluia !!
Page generated in 0.31817 seconds with 84 queries
