"Dirthead 509" TJ Project - Page 10 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 21st, 2009, 08:03 AM   #181
KennyOffroad
Ridge Runners Offroad
KennyOffroad's Avatar
Are you done yet ?
Old May 21st, 2009, 08:08 AM   #182
Simply put, no its not done yet
Old May 21st, 2009, 08:10 AM   #183
xj4life
xj4life's Avatar
i cant believe i missed all the update posts lately. looking really good brandon. i really like it.
Old May 21st, 2009, 10:28 PM   #184
Thanks
Had a piece of the rear frame crossmember that I used the plasma to clear out of the way fall on my air hose so I fussed around with that for over an hour this morning trying to get it to seal back up. Should have just went to the hardware and got the right fitting
Going to seal the fuel cell cover to the bottom and the fuel filler side. That should allow me to run the fuel filler where YJ's run them and still have the passenger compartment sealed off from the gas tank.
Got my front spring/shock combo via UPS today Need to change the springs but I have more research to do on that first
Old May 21st, 2009, 10:30 PM   #185
Old May 21st, 2009, 11:29 PM   #186
xj4life
xj4life's Avatar
bling bling yo
Old May 30th, 2009, 10:23 PM   #187
Fuel cell cover hotness Took alot of time today to get something so simple built. I did "make" a break and put it to work
Old May 30th, 2009, 11:11 PM   #188
s.hembree
s.hembree's Avatar
Where is the hotness part?
Old May 31st, 2009, 08:15 AM   #189
I know it's hard for you to comprehend being that it doesn't just bolt on
Old May 31st, 2009, 11:49 AM   #190
VonDirt
VonDirt's Avatar
tidy work dude
youll be out and tearing up stuff in no time !
VonDirt is offline   Reply With Quote
Old May 31st, 2009, 05:55 PM   #191
Originally Posted by VonDirt View Post
tidy work dude
Thanks!
I'm hoping to make it to the badlands in August if I can find another job by then for fundage
Old June 5th, 2009, 12:02 PM   #192
pjku79
pjku79's Avatar
Damn yo. You've been busy since I moved down to TX. Nice rig you got going. What happend to piecing rigs together for $500?
pjku79 is offline   Reply With Quote
Old June 5th, 2009, 02:58 PM   #193
What are you talking about, I bought this one for less than that
Old June 5th, 2009, 03:10 PM   #194
pjku79
pjku79's Avatar
maybe for the piece you started with.
Old June 5th, 2009, 03:36 PM   #195
Yea, and I've been building it $500 at a time since
Old June 12th, 2009, 03:38 PM   #196
So lately I've been fighting with my fuel cell.
Tip for straightening out the channels in the tub:
Cut down through the center, hit with hammer both sides same time, weld back together and grind. Turns out pretty flat.
I finally got most of the fab work done today. Just need to burn it all home yet. I'll do that this afternoon yet hopefully.
Skid/carriage:
Hinged the straps so I could get the fuel cell back out if I need to. Also have black plastic all the way around the tank to keep it from rubbing on the body.
Cover installed
From the outside
Look at all that real estate
Old June 12th, 2009, 03:46 PM   #197
s.hembree
s.hembree's Avatar
I used to have a set of jack stands just like those...
Old June 12th, 2009, 03:51 PM   #198
They work fantastic, you should find them I used to have a welding blanket and welding clamps, I'll trade you soon
Thanks for letting me use them
Old June 12th, 2009, 07:24 PM   #199
Welded in:
Semi-finished photo's. Still need to figure out what I'm going to do with the poop fuel pump adapter from copperhead fab, get the inlet plumbed to the back of the jeep and put the fuel lines in.
Ordered corner guards from Barbed Wire Off Road on ebay. $157 to the door for 3/16 blank corner guards pre- bent. Wanted to order dimple dies too but it's a little late in the build for that.
http://stores.shop.ebay.com/Barbed-W...__W0QQ_armrsZ1
Old June 24th, 2009, 04:30 PM   #200
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
done yet?
Page generated in 0.48594 seconds with 84 queries
