ranger problem - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 16th, 2008, 05:45 PM   #1
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
Default ranger problem
94 ranger....pulled the front end into the garage to change the water pump and t-stat. went to pull it out and no forward or reverse. you can hear the click when u put it into gear but i think thats just the detents on the shift lever. the fluid was good but we droped the pan to check if the filter was cloged. filter is fine and the fluid seemed ok not metal or anything. any ideas would help.
'09 "Sparkly Tan" Jeep Patriot
http://badges.fuelly.com/images/smallsig-us/306663.png
CLICK HERE TO GET RID OF ME
Originally Posted by PCK_4xCustoms View Post
cunt punt, it's like a reset switch for women.
sQUEAK003 is offline   Reply With Quote
Old November 16th, 2008, 06:29 PM   #2
chris1044
chris1044's Avatar
1) Engine size???
Either way, it's odd that it went there under its own power and now wont move.....my only guess is that the main spool valve in the valve body isn't in its proper location, or the pump is bad.....if it were me, I would have checked the main line pressure prior to pulling the pan. This still should be done, but now that you've dropped the pan refilling it may be a waste of ATF (unless you re-use the old stuff)
Old November 16th, 2008, 06:31 PM   #3
tcxtreme1000
Mud Slut-Hit Every Hole!!
tcxtreme1000's Avatar
Tcase in N?
tcxtreme1000 is offline   Reply With Quote
Old November 16th, 2008, 07:16 PM   #4
chris1044
chris1044's Avatar
Originally Posted by tcxtreme1000 View Post
Tcase in N?
impossible unless you have the uber rare 1354 manual......in which case I'm jealous
Old November 16th, 2008, 10:06 PM   #5
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
its the v-6 auto trans 2wheel drive.......not sure on the motor size ill have to figure that out
Old November 16th, 2008, 10:22 PM   #6
04 EDGE
Floor Shift Maddness!
04 EDGE's Avatar
is the shift cable hooked to the transmission?
and i have a 1345M in my truck
Old November 17th, 2008, 11:35 AM   #7
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
yeah and pulled the pan it was moving inside the trany too.....
Old November 17th, 2008, 01:18 PM   #8
fsumotorhead
N8KVB
fsumotorhead's Avatar
Dumb question, but did you put fluid back in?
Old November 17th, 2008, 01:29 PM   #9
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
yeah........lol.......its on its way to dougs trans now
Old November 17th, 2008, 01:31 PM   #10
04 EDGE
04 EDGE's Avatar
well at this point you need to check line pressure. sounds like the pump took a dump.
Old November 19th, 2008, 10:09 PM   #11
DeRanged mudder
completly insane
DeRanged mudder's Avatar
Send a message via Yahoo to DeRanged mudder
Wow, You changed the waterpump and still don't know the size of your motor? How is that possible?
DeRanged mudder is offline   Reply With Quote
Old November 20th, 2008, 12:15 AM   #12
bigblockford79
Big Block Ranger
bigblockford79's Avatar
x2
Old November 20th, 2008, 11:48 AM   #13
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
not my truck.... its the in-laws......and i did state that its the v-6....i didn't buy the parts i just changed em....not that hard to pull a few bolts put a new gasket on and put the bolts back in.....
Old November 20th, 2008, 11:50 AM   #14
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
o and by the way.....found out whats wrong.....when the prev. owner mated the "rebuilt" trans the the "rebuilt" motor he must not have cared cause the torque converter got crammed into the pump and took them both out.....only had the truck for a week and we got it for $700.....
Old November 20th, 2008, 10:21 PM   #15
DeRanged mudder
completly insane
Oh, that sucks!
'94 had 2 different v-6s that were very different motors. 3.0 and 4.0.
$700 WAS a good deal.
Old November 20th, 2008, 10:26 PM   #16
yep gotta make sure the torque convertor is fully seated into the bump before cramming the bell housing bolts into the block.
Page generated in 0.54139 seconds with 71 queries
