Amber's spare parts XJ. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 16th, 2008, 02:54 PM   #1
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Default Amber's spare parts XJ.
Bought this XJ for amber last year from a customer after his son got into and accident with it.
The front sheet metal had some damage, slightly tweaked frame in front of the coil bucket, and a bent control arm and mount.
So I fixed the frame, pulled the fender and hood out, painted and installed a new front grill, and we build a bumper with frame tie-ins to keep everything straight.
A few months later it started wandering and I found the TRE taper in the knuckle was sloppy. I had a set of WJ knuckles with calipers; so I figured what the hell, put them on with some wheel spacers to clear the stock wheels, and bolted the stock XJ steering back up.
On our honeymoon the trac bar started to get sloopy, and now it's getting slippery so it was time for new tires.
I already had the WJ stuff on there, had another set of wheels, and some XJ springs that have been sitting around waiting for someone to use them, and a set of shocks that Kirby gave me. So I snagged some 31's off here and got started buying the other small parts I needed.
It would be silly not to make it cooler
Front springs and shocks.
Adapter since the shocks didn't have a stud.
TRE's
Built a tracbar
All put together.
Draglink bent to clear mounts.
Stupid rear shock mounts
On the ground!
I am not sure what springs these are, but it looks like around 3-4" of lift. The rear is an add a leaf, so it rides pretty stiff. It could use some front control arms to center the tire better in the wheel well, but it doesn't rub, so I don't think I am going to mess with it.
Steers and stops awesome. 2 degree rear shims and a .5" Tcase drop killed the vibes.
Nothing super hardcore, just a cool, low buck DD for the wife
JcrOffroad
Zoom Zoom!
Old November 16th, 2008, 04:12 PM   #2
ddeadserious
ddeadserious's Avatar
Very nice.
ddeadserious is offline   Reply With Quote
Old November 16th, 2008, 04:12 PM   #3
4x Fanatic
Guiness Test Pilot
4x Fanatic's Avatar
Looks good but we really needs Amber in the pics!
4x Fanatic is offline   Reply With Quote
Old November 16th, 2008, 04:38 PM   #4
Nuzzy
likes him some Red Dog
Nuzzy's Avatar
Needs speed holes
Nuzzy is offline   Reply With Quote
Old November 16th, 2008, 04:42 PM   #5
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
look's good... were are the rock sliders?
Old November 16th, 2008, 04:47 PM   #6
ckupq
Kitten I'm gonna eat you!
ckupq's Avatar
Did you use whole outer WJ knuckles? (hubs, stub shafts, knuckles and brakes)
ckupq is offline   Reply With Quote
Old November 16th, 2008, 05:19 PM   #7
OnlyInMyXJ22
No Money = No Fun
OnlyInMyXJ22's Avatar
Nice!
*2007 Rubicon
*2006 Duramax
Old November 16th, 2008, 06:55 PM   #8
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
It needs sliders and a rear bumper... just have to find the drive to make them
JcrOffroad
Zoom Zoom!
Old November 16th, 2008, 06:56 PM   #9
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
No. I used the WJ knuckles, rotors, calipers, XJ hubs, XJ stubs. I drilled the rotors to 5 on 4.5 and made a .25" spacer to push the hub out.
JcrOffroad
Zoom Zoom!
Old November 16th, 2008, 07:20 PM   #10
kickstand
circling the drain
kickstand's Avatar
Originally Posted by Monkeyevil View Post
It needs some sort of windsheild bar... just have to find the drive to make them
I concur.
Looks good daryl, I like
Old November 16th, 2008, 08:12 PM   #11
KartRacer
Blowd up
KartRacer's Avatar
Way to make do... Looks good.
Old November 16th, 2008, 09:07 PM   #12
hman1991
hman1991's Avatar
Send a message via AIM to hman1991
a set of s10 springs in rear proly soften it up and let it set prety level.
hman1991 is offline   Reply With Quote
Old November 17th, 2008, 02:41 PM   #13
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
A customer a while back had a set on his XJ and I didn't like they way they rode personally. I don't mind the stiffer ride of add a leafs at all.
If I pickup a new body style I may do new softer springs at that point when I move parts over, but I'm not going to mess with it right now
JcrOffroad
Zoom Zoom!
Old November 17th, 2008, 04:28 PM   #14
Dave Kerwin
web wheeling, hard.
Dave Kerwin's Avatar
gotta love it
Old November 17th, 2008, 07:41 PM   #15
wakeboard76
wakeboard76's Avatar
nice little rig...I (and I'm sure others) would like to hear the details of adding those WJ knuckles and what that entails.
wakeboard76 is offline   Reply With Quote
Old November 17th, 2008, 08:08 PM   #16
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
http://www.greatlakes4x4.com/showthread.php?t=42548
JcrOffroad
Zoom Zoom!
Old November 17th, 2008, 08:41 PM   #17
Stan
I got a gold chain
Stan's Avatar
Nice
Stan is offline   Reply With Quote
Old November 17th, 2008, 08:57 PM   #18
bitchofanxj
Are you cooool maaaann?
bitchofanxj's Avatar
Nice cherokee, plan on doing the same steering setup on mine.
bitchofanxj is offline   Reply With Quote
Old November 17th, 2008, 09:13 PM   #19
kargod
Charcoal Mellowed
kargod's Avatar
I really like those driving light mounts and surrounds in the front bumper.
You are truly an ar-teest with fabwork
kargod is offline   Reply With Quote
Old November 19th, 2008, 05:37 PM   #20
wakeboard76
Thanks for the WJ Knuckle conversion thread...I remember reading it, but couldn't remember where.
Page generated in 0.37171 seconds with 83 queries
