Custom Powder Kote - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > Great Lakes 4x4 Marketplace > Support your local GL4x4 member owned business
Old November 14th, 2008, 07:45 PM   #1
CPK_Jim
Powder Coater
CPK_Jim's Avatar
Default Custom Powder Kote
Hi all,
I am new in town and do custom powder coating. We specialize in auto and bike parts. Ok, Here is a little bit of info about powder kote that some of you may not know, I didn't. There are over 6,000 different colors to choose from, including metallics, candies, chameleons, iradescents, clears and more. Also its not just glossy anymore, we can do flats and satins as well. Not just smooth anymore, we can do various different textures including wrinkles, viens, leatherettes, sandpaper like and various other textures as well as smooth. Multiple kotes is another option we offer, for example: silver flake clear over your color(orange?) for that little extra sparkle(BTW the silver flake reflects back the color it is over, orange makes the flake look orange). This is only a taste of what is possible, got an idea for something that you want done, contact us and we will let you know if it can be done.
We are a unique powder kote company, because we will do 2-tone and other multiple colors as well as custom designs with powder kote, most companies wont even consider it. Got questions that i havent answered? Post a reply with your question, we will check back often. Or you can always give us a call.
Jim
Web: http://www.custompowderkote.com
email: jim@custompowderkote.com
phone: (989) 992-6696
CPK_Jim is offline   Reply With Quote
Old November 14th, 2008, 08:25 PM   #2
oz97tj
Wasn't this attached?
oz97tj's Avatar
I've never thought about powdercoating a header before. Does it hold up to the heat? Do it provide any level of heat reflection like ceramic or wrapping it does?
********GLFWDA.org********
Old November 14th, 2008, 08:33 PM   #3
CPK_Jim
Powder Coater
CPK_Jim's Avatar
That is high temp powder coat good up to 1200 F It holds the heat some but I dont think to the level of wrapping, but if you plan to wrap you may want to have them coated so they dont rust.
Jim
Old November 14th, 2008, 08:37 PM   #4
oz97tj
oz97tj's Avatar
Jim
Is this stuff different than the powder coat you can apply yourself? The stuff you can do yourself in your over cures at just a couple hundred degrees. Or is it basically cooked so it won't melt back off? It was my understanding it was basically plastic that was melted.
Forgive me if I sound stupid. I'm just trying to learn. lol
Old November 14th, 2008, 08:50 PM   #5
CPK_Jim
Powder Coater
CPK_Jim's Avatar
This high temp, Im not sure exactly what it is made of but its definately different than normal powder coat. This has a higher cure temp than normal powder coat it also smells much different in the cure cycle. Even regular powder coat once it is cured doesnt remelt, untill you reach its limits, regular powdercoat may start to discolor at about 550 but doenst start to burn off till about 750. And yes if you had the equipment to do it you could DIY.
Jim
Old November 14th, 2008, 08:52 PM   #6
oz97tj
oz97tj's Avatar
Jim
The diy stuff I was thinking about is the stuff you can get from Sears. Supposedly you can spray it with one of the guns and then you can cure it in a regular household over (although not one used for food).
Old November 14th, 2008, 08:56 PM   #7
CPK_Jim
Powder Coater
CPK_Jim's Avatar
This is not the same powder as the stuff from sears. And you may have a hard time fitting your header in a normal oven. But for regular stuff that is small sure you could do that, but just beware its not as easy as they make it out to be.
Old December 1st, 2008, 05:45 PM   #8
Marine_mike
SNSHTF
Marine_mike's Avatar
Hey... what's the biggest item that you can coat? I want to have my cage blasted and powder coated Coyote Tan.
Marine_mike is offline   Reply With Quote
Old December 1st, 2008, 10:27 PM   #9
CPK_Jim
Powder Coater
CPK_Jim's Avatar
If it will fit in a 3' X 5' X 6' cube I can coat it.
Jim
Old December 2nd, 2008, 01:08 AM   #10
epix
epix's Avatar
Sweet stuff man! are you able to do brake calipers? I have a set of 2006 Corvette Calipers I'd like done in orange if possible.
epix is offline   Reply With Quote
Old December 2nd, 2008, 07:55 AM   #11
CPK_Jim
Powder Coater
CPK_Jim's Avatar
Yes I can do brake calipers. Heres some pics of some that I did.
Jim
Old December 3rd, 2008, 12:18 PM   #12
epix
epix's Avatar
Those look awesome! That color would be perfect on my Typhoon.
pic with the stock brakes
What would be the cost of having a set of front and rear C6 Corvette calipers done in that shimmer orange? I believe my brackets are already powder coated black.
Old December 3rd, 2008, 01:07 PM   #13
TFin04
How much for 4 stock cherokee wheels coated black? Very minor rust on the rim would probably need to be bead blasted first. I may be able to blast them myself but I don't know if they will fit in my cabinet.
TFin04 is offline   Reply With Quote
Old December 3rd, 2008, 01:09 PM   #14
CPK_Jim
Powder Coater
CPK_Jim's Avatar
Nice Typhoon!!
PM Sent.
Jim
Old December 3rd, 2008, 01:17 PM   #15
CPK_Jim
Powder Coater
CPK_Jim's Avatar
PM Sent.
Jim
Old December 4th, 2008, 12:56 AM   #16
epix
epix's Avatar
I didn't get the PM, can you resend it?
Old December 4th, 2008, 07:56 AM   #17
CPK_Jim
Powder Coater
CPK_Jim's Avatar
Resent.
Jim
Old December 4th, 2008, 08:54 AM   #18
95geo
newbie
95geo's Avatar
any way you can get something 10'x6'x6' in an oven?
Old December 4th, 2008, 11:35 AM   #19
CPK_Jim
Powder Coater
CPK_Jim's Avatar
It wont fit in my oven unless your item comes apart. There are places with ovens that big. I will hopefully eventually have one that big, but that wont be till after I move to a bigger shop.
Jim
BTW just curious, what is the item you want done?
Old December 10th, 2008, 10:04 PM   #20
zthatzmanz28
Life on a lazy river
zthatzmanz28's Avatar
saw that honda block in the gallery...typical price to do a 4 cylinder block?
zthatzmanz28 is offline   Reply With Quote
Page generated in 0.74665 seconds with 83 queries
