Cam choice for 351w? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 13th, 2008, 02:23 PM   #1
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Default Cam choice for 351w?
I am thinking a E cam since it is a roller cam motor. Would the F cam be to much?
Old November 13th, 2008, 07:26 PM   #2
fordlovinfarmer
CHEAP
fordlovinfarmer's Avatar
Go with the X
fordlovinfarmer is offline   Reply With Quote
Old November 13th, 2008, 07:39 PM   #3
frdboy
frdboy's Avatar
What else is done to the motor?
What is it going to be used for mostly?
Old November 13th, 2008, 07:48 PM   #4
Jeepaholic
Jeepaholic's Avatar
stock for now with gt40 efi setup, might get gt40 heads if I can find some for reasonable. I figure while the intake is off I would throw in a cam to wake it up.
Bronco on 40's, trail rig with some road time
Old November 13th, 2008, 07:54 PM   #5
special k
special k's Avatar
what gears you runnin?
Old November 13th, 2008, 08:19 PM   #6
frdboy
frdboy's Avatar
Do you run a MAF sensor?
Old November 13th, 2008, 09:16 PM   #7
Jeepaholic
Jeepaholic's Avatar
yes I have a mass air ecu I am using
4:10's for now but will have a doubler (203/205)
Old November 13th, 2008, 09:18 PM   #8
special k
special k's Avatar
do you want low end torque or high end hp?
Old November 13th, 2008, 09:20 PM   #9
Jeepaholic
Jeepaholic's Avatar
both, duh
Probably torque
Old November 13th, 2008, 09:40 PM   #10
frdboy
frdboy's Avatar
I have a "unknown" cam I pulled out of a mustang, hyd. roller, lobe lift .300 on both works out to .480 valve lift with 1.6 rockers. I never did measure duration, it may be a B cam. It had a fairly rough idle and had about 8" vac. in a 302. pm me if your interested.
Page generated in 0.21217 seconds with 53 queries
