f250 trans - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 8th, 2006, 09:15 PM   #1
72cj304
72cj304's Avatar
Default f250 trans
can you put a a4od from a 96 f150 with a 351 behind a 96 f250 with a 460 the 460 has a bad trans and I have one from a 351 what would I have to change thanks
72cj304 is offline   Reply With Quote
Old May 8th, 2006, 10:07 PM   #2
frdtrckmnrich
FORD The Best Never Rest
frdtrckmnrich's Avatar
Default f250 trans
NO. the 351 is a windsor block which is a small block bellhousing. the 460 is a big block.
Old May 9th, 2006, 06:49 PM   #3
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
you might be farther ahead to pull the trans and go talk to Denny Haas at the trans shop (Haas transmission) he can rebuild it as a bench job and have it back in a couple of days.
Yetti
Old May 9th, 2006, 09:50 PM   #4
72cj304
72cj304's Avatar
thanks for the input so much for cheep and easy
Old May 9th, 2006, 09:54 PM   #5
72cj304
72cj304's Avatar
thanks haas trans is about 3 miles from my house I would let denny do the work but I just know one of his monkeys would put his hand on and I will not make that mistake ever againbut thanks
Old May 10th, 2006, 02:04 AM   #6
Yetti
Yetti's Avatar
I understand your sentament towards his monkeys.
I have another guy in Chelsea that does bench jobs. his name is Andy Hasencamp. he works as a trans man at the chevy dealer and rebuilds trannys for everything else at his house. you can call him at 475-8663 (its Fiast/Diesings number)he will talk to you though.
Yetti
Page generated in 0.26293 seconds with 41 queries
