**SOLD**86 Pontiac Firebird no motor or trans. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 11th, 2008, 08:44 PM   #1
cole
Need more susp travel...
cole's Avatar
Default **SOLD**86 Pontiac Firebird no motor or trans.
86 Firebird no motor, transmission, radiator or t-tops, but everything else is there as far as I know. Mileage looks to be about 135K.
I bought it for parts and then didn't use any.
Dash is in good shape.
Interior is good shape as well. Driver seat is a little worn but not through in the typical spots.
Forgot to mention, no head liner in car. Seems to be a common problem from what I have found.
If there are questions I'll find out what I can. Bought without motor and trans so never had it on the road.
$250 obo
May part out if doesn't go but would like to get it out of the yard.
T-tops shown in picture are on to keep weather out and do not go with the car. (T-tops can go with car for an additional charge.)
Could deliver for cost of fuel to a reasonable distance.
Looked up VIN number and the car is the Special Edition not the base model. I did not get a chance to dig into it to find out what the Special Edition entailed but that's what it is. Car originally a LG4 motor (305 carb).
**Found from the information tag that the car has a 2.73 rear end, not limited slip. This is good for mpg, I got over 20mpg in a TA with a 305 and a 2.73 rear.
Also I just had a battery hooked up to it and the power windows seem to work good. The power lock click and the lever moves but does not fully engage. I had a different car where I cleaned the contacts and that took care of the problem. I'm not sure if this is the same or not. I also tried the lights out and they seem to go up good. They did hesitate a bit on the way down but after turning on and off a few times it seemed to do fine.
**Any interest if I part it out? Let me know what you may need. If there is enough interest I'll part it.
Interior and engine bay pics on page 2
cole is offline
Old November 11th, 2008, 09:16 PM   #2
waterdog
looks like t-tops are there?
waterdog is offline
Old November 11th, 2008, 10:48 PM   #3
Cherokee23_98
Cherokee23_98's Avatar
x2
Cherokee23_98 is offline
Old November 12th, 2008, 06:42 AM   #4
cole
cole's Avatar
The tops are currently on the car to keep the weather out. I was not planning on selling them with the car.
For the right price the tops can go with the rest of the car.
Sorry for the confusion.
cole is offline
Old November 13th, 2008, 06:00 PM   #5
cole
cole's Avatar
Bump, any questions?
cole is offline
Old November 14th, 2008, 02:51 PM   #6
cole
cole's Avatar
Weekend Bump.
cole is offline
Old November 15th, 2008, 10:46 AM   #7
cole
cole's Avatar
Bump
cole is offline
Old November 16th, 2008, 09:04 PM   #8
cole
cole's Avatar
ttt
cole is offline
Old November 17th, 2008, 03:32 PM   #9
cole
cole's Avatar
Slap a motor and trans in it this winter and drive around next summer with the tops off.
cole is offline
Old November 18th, 2008, 02:54 PM   #10
cole
cole's Avatar
Any offers?
cole is offline
Old November 18th, 2008, 03:44 PM   #11
scrambled82
scrambled82's Avatar
rust?
scrambled82 is offline
Old November 18th, 2008, 06:34 PM   #12
cole
cole's Avatar
There is some rust but not bad for an 86. The second picture, (the side profile) you can make out the worst of it. Around the wheel wells like normal, mostly at the bottoms front and rear. There is a dent on the driver side fender right next to the hood.
I have not looked under the car much so I don't know about rust under. The exhaust looks newer.
I can get pics of a specific area or better ones of the rust if wanted. I have to dig up a camera so it might take me a couple days. I can also post or email larger pictures as well. Let me know what you want to see and I'll get it.
cole is offline
Old November 18th, 2008, 06:50 PM   #13
thegoodfellas504
Do you know if it had a TBI motor in it or carb?
thegoodfellas504 is offline
Old November 19th, 2008, 09:34 AM   #14
cole
cole's Avatar
I'll check the VIN tonight when I get home and find out what it was originally.
cole is offline
Old November 19th, 2008, 06:16 PM   #15
cole
cole's Avatar
The original motor was a LG4 which from what I could find appears to have been a carb motor.
Looking at the VIN the car also appears to be the Special Edition not a base model. I'm not sure what the Special Edition entails but that's what it is.
Hope that helps. Let me know if there are any other questions,
cole is offline
Old November 19th, 2008, 06:59 PM   #16
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
contact info? pm me address, name and number
Kodiak450r is offline
Old November 19th, 2008, 09:51 PM   #17
cole
cole's Avatar
PM sent
cole is offline
Old November 20th, 2008, 01:22 AM   #18
scare-crow
the eskimo bro
scare-crow's Avatar
Send a message via AIM to scare-crow
the only reason its a "special edition" and not the base model is because its a t-top
scare-crow is offline
Old November 20th, 2008, 09:32 AM   #19
cole
cole's Avatar
Good to know, thanks.
cole is offline
Old November 21st, 2008, 09:32 AM   #20
cole
cole's Avatar
Bump
cole is offline
Page generated in 1.32798 seconds with 83 queries
