89 Rbv - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 11th, 2008, 02:12 PM   #1
fordlovinfarmer
CHEAP
fordlovinfarmer's Avatar
Default 89 Rbv
I just got this 89 Bronco II on saturday in a trade for my BB F150. Its solid no rust, has fresh paint. The bad is it has no interior and no drivetrain in place. It came with (2) 2.9 v6 w/ trans and tcases and a 302 w/aod out of a 86 Cougar. I started cleaning the inside out removing all the screws that were left. My plans are making a dash and bedlining the floor. I'm planning on getting some thin aluminum sheet to make all my panels and I will have to locate some seats. I'm gonna throw the 302 in and hopefully I can figure out a way to use the tbi instead of converting over to a carb.
This is the 302
Engine Bay
Driver side
Passenger side
I started on the interior, its gonna be fun when I get up to the front and have to scrape all the old insulation off.
fordlovinfarmer is offline   Reply With Quote
Old November 11th, 2008, 03:48 PM   #2
98-S10-lifted
98-S10-lifted's Avatar
looks good, and got a decent start for a project.
98-S10-lifted is offline   Reply With Quote
Old November 11th, 2008, 05:54 PM   #3
fordlovinfarmer
CHEAP
Thats what I thought, I just need a tranny.
Old November 11th, 2008, 08:31 PM   #4
88mudder
In the band!
ill sell u the AOD for cheap if you come get it. If i had a decent DD i would deliver or make a trade for that 2.9
Old November 12th, 2008, 12:03 AM   #5
fordlovinfarmer
CHEAP
How much we talkin?
Old November 13th, 2008, 09:41 AM   #6
88mudder
In the band!
Originally Posted by fordlovinfarmer View Post
How much we talkin?
$80
Old November 18th, 2008, 01:14 PM   #7
fordlovinfarmer
CHEAP
well, I've got a little more done over the past couple days. I took of the fenders, grill, headlight assembly's to make it easier to put the 302 in. My girlfriend finished grinding and primering the floor while I starting tearing into the v8.
Old November 18th, 2008, 01:18 PM   #8
lepp1892
WebWheeling1KeyAtaTime
lepp1892's Avatar
She's a keeper...
lepp1892 is offline   Reply With Quote
Old November 18th, 2008, 01:25 PM   #9
buzz
buzz's Avatar
Wow nice find!! Any plans for lift and tires?
buzz is offline   Reply With Quote
Old November 18th, 2008, 01:29 PM   #10
fordlovinfarmer
CHEAP
I kind of want to keep it short and wide. It already has a 3 in. body lift.
***She will be keeper if I can get her to do the bedliner too***
Old November 26th, 2008, 12:50 PM   #11
Bronco Ollie
Captain Jack Sparrow
Bronco Ollie's Avatar
nice looking b2
Bronco Ollie is offline   Reply With Quote
Old November 26th, 2008, 05:58 PM   #12
fordlovinfarmer
CHEAP
thanks....found a fullsize 5 speed with a 1356 case last weekend. Hopefully its not to long or I will have to find a different transfer case. But I'm still gathering parts and trying to get the motor cleaned up.
Old November 26th, 2008, 06:01 PM   #13
88mudder
In the band!
sweet stuff. The case will fit with alittle trimming or if you keep the crossmember low enough it will clear the framerail.
Old November 26th, 2008, 06:05 PM   #14
fordlovinfarmer
CHEAP
I figured that much...I'm just worried about the length and having a really short driveshaft
Old November 26th, 2008, 11:32 PM   #15
88mudder
In the band!
should be about the same length as a stock shaft. Just use the factory trans mount holes on the frame if you can.
Old January 22nd, 2009, 05:38 PM   #16
fordlovinfarmer
CHEAP
I haven't updated this in a while, but I got a little done. The interior is rhinolined. I've got the engine and trans in. The front clip is back on and I will get the transfer case back in tomorrow.
Old January 22nd, 2009, 05:44 PM   #17
Dave Kerwin
web wheeling, hard.
Dave Kerwin's Avatar
nice!
I never understood what rvb meant, halp
Old January 22nd, 2009, 06:43 PM   #18
YellowYJ
YellowYJ's Avatar
Looks good, that thing is clean.
YellowYJ is offline   Reply With Quote
Old January 22nd, 2009, 07:30 PM   #19
fordlovinfarmer
CHEAP
It means "Ranger Based Vehicle". Thanks, its pretty solid. Its gonna need a core support here in the near future, but other than that its solid. It had everything painted not to long before I got it.
Old January 22nd, 2009, 10:31 PM   #20
88mudder
In the band!
sweet
Page generated in 0.28422 seconds with 83 queries
