rusted piston rings - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 10th, 2008, 09:01 PM   #1
bacongrease
Am i still a Noob?
bacongrease's Avatar
Default rusted piston rings
i have a 360 that has been sitting for 2 years, and now it wont turn over...
being that it turned over when it was pulled im guessing that the rings are "stuck" rusted, seized whatever
any remedys??
i tried 10w30 down the cylinders and let it sit and still nothing...
its on the engine stand so i can pull it apart, just want to know if theres a simple fix..
thnx
bacongrease is offline   Reply With Quote
Old November 10th, 2008, 09:10 PM   #2
mudd_jumper
mudd_jumper's Avatar
my cuz did this on an old for flattie van dumped Wd40 in the cylinders let it sit for a week. then broke it free with a BIG a** breaker. with the plugs out he turned it till all the WD was out then put them back in and drove it for 3 years..... Your results may very
Old November 10th, 2008, 09:17 PM   #3
Nuggets
I fix stuff!
Nuggets's Avatar
I like a mix of ATF and brake fluid to unsieze grumpy old motors. Pour, ignore, attack in a few days.
Old November 10th, 2008, 09:26 PM   #4
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
I've heard of people using PB Blaster...
Spray in the cylinders, let sit for a while....few days than turn it over with a socket.
Old November 11th, 2008, 09:09 PM   #5
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
I skip the part with brake fluid and use striaght ATF...I have done this to a few motors with good results
Old November 11th, 2008, 09:11 PM   #6
wingman573
Here and gone
wingman573's Avatar
x2
wingman573 is offline   Reply With Quote
Old November 12th, 2008, 06:04 AM   #7
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
i have a 440 that i had to break free due to severe rusted cylinders. i tried everything listed and then some. ATF seemed to work the best. i ended up breaking all but 3 pistons to pieces getting them out. o well
Old November 12th, 2008, 11:38 AM   #8
bj house
bj house's Avatar
PB blaster/heat/repeat. Took a week of doing that every night but I busted loose my dad's bike that had been seized for over twenty years.
Old November 12th, 2008, 12:01 PM   #9
Pokerob
hug life
Pokerob's Avatar
A 258 sat in my yard for 2 years uncovered filled to the brim with water.
I pushed it over - dumping out all the water, pulled the pan and cleaned out the sludge.
I thne pulled out all the plugs and dumped a few ozs of atf down each cyl and a few ozs down the carb.
Hand turned with a breaker bar, then cranked with battery (plugs left out),
put plugs back in , started right up and ran for 2 years until i sold the jeep.
Old November 12th, 2008, 12:13 PM   #10
Sluefoot26
Mudhowg's a Homo
Sluefoot26's Avatar
I heard Diesel works well, never tried it myself??
Sluefoot26 is offline   Reply With Quote
Old November 12th, 2008, 12:24 PM   #11
Renegade II
Coil springs are for pens
Renegade II's Avatar
Fuel oil / diesel works well. Have used them to loosen up a couple old tractor engines. Let it set a couple days. Too bad there is no easy cure for the rust pits that will remain in the cyl wall
Old November 12th, 2008, 12:38 PM   #12
Pokerob
hug life
Pokerob's Avatar
JB Weld
Page generated in 0.26938 seconds with 59 queries
