22RE header install - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 10th, 2008, 11:24 AM   #1
BOGDOG
BOGDOG's Avatar
Default 22RE header install
I have an extra header and need to replace most of the exhaust on my 89 yota P'up. How much of a hassle is the header install? Would it be worth the trouble on a beater that I may not keep much longer? How do they run with no O2 sensor? No provision on header. I could add one if needed. Truck sucks gas anyway.
Old November 14th, 2008, 01:28 PM   #2
Swansen
without a O2 sensor they run like crap. I haven't ever had any problems getting bolts off the manifold, just make sure to use liberal amounts of penetrating fluid, (PB blaster or whatever) The only thing that will give your grief will be the two bolts on the cat, they will be a fun time, i'm sure. but if your have a torch, or cutting tool you can just cut them off.
Swansen is offline   Reply With Quote
Old November 15th, 2008, 12:21 PM   #3
skife
skife's Avatar
just replace the whole exhause, I beilve the downey header has a bung for an o2 sensor on it
Old November 17th, 2008, 11:55 AM   #4
BOGDOG
BOGDOG's Avatar
I plan on replacing the whole exhaust but I am not going to spend the money on a new header, I may try to weld a bung on the header I have if I use it.
Old November 17th, 2008, 12:11 PM   #5
skife
skife's Avatar
it'd be easier just to have a bung welded on to the exhaust after the header.
Old November 23rd, 2008, 09:41 AM   #6
7mRunner
Love/Hate Turbo 4Runner$
7mRunner's Avatar
Putting a Bung in #2 or at merge collector are the best places.
Just remember, you can't cut and splice to extend the wires...
7mRunner is offline   Reply With Quote
Old November 23rd, 2008, 12:42 PM   #7
skife
skife's Avatar
thats why my yota ran like a box of dog turds, when the P/O replaced the motor, he didn't make sure all the wiring was off the exhaust, so the O2 sensor plug melted together, then was cut and connected with butt connectors.
Page generated in 0.32848 seconds with 44 queries
