Seal Battery - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 8th, 2008, 01:24 PM   #1
AWK
AWK's Avatar
Default Seal Battery
Has anyone here opened a so called sealer battery and added water? I have a weak YUASA YTX20LBS, it states it sealed, but it easily opened. When opened is appears to be the same as a simple lead acid battery and low on acid. I need a new one anyway, so I added water and it appears to be taking a trickle charge ( I haven't left it alone on the charger). Wondering if anyone has had sucess with this. I bought this sled used, I rarely have a battery issues because I keep them full, charged, and stored off season.
I hate to relace it if it's only low and in need of a charge. The cell cover looks like a great improvement for the manufacturing process.
75 bucks for a new one at Walmart.
Thanks
AWK
AWK is offline   Reply With Quote
Old November 8th, 2008, 01:28 PM   #2
Yota Bill
it is just a lead acid battery...but I hope you didnt use tap water...the minerals and other substances in the tap water will collect on the plates and kill the battery...basically, they will cause an open circuit...
Old November 8th, 2008, 01:36 PM   #3
AWK
AWK's Avatar
I use distilled, same as I do for all my deep cycles, ATV, Motorcycle. I just replaced a battery on a 1994 ATV. I take care of batteries. Clean and store them in off seasons, and pull scheduled maintance on them. I have space in garage set-up just for batteries. This is my first "sealed" battery, other than for may cars.
AWK
Old November 12th, 2008, 12:08 PM   #4
chris1044
chris1044's Avatar
AWK
Care to elaborate on this? What is it - do you have like a mass trickle charge station? Curious because I do the same thing as you, wondering how you're doing it.....
Old November 12th, 2008, 12:23 PM   #5
XXXJ
Desert Rat
XXXJ's Avatar
It's like maintence free U-joints.
They delete the access point so you will buy a new one instead of maintain it.
Page generated in 0.20937 seconds with 38 queries
