1989 Ford Ranger engine swap - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 6th, 2008, 04:04 PM   #1
holeshot13
holeshot13's Avatar
Default 1989 Ford Ranger engine swap
I am about to swap out the 2.9 in my 89 ranger to a 4.0 out of a 92 ranger. I was just wondering if anyone has done this swap? Do you have any tips? Thanks
holeshot13 is offline   Reply With Quote
Old November 6th, 2008, 07:22 PM   #2
04 EDGE
Floor Shift Maddness!
04 EDGE's Avatar
your gonna need the PCM, fuel pump, wiring harness, radiator off the 4.0 truck. however it should just bolt in.
what trans do you have?
Old November 7th, 2008, 07:42 AM   #3
holeshot13
holeshot13's Avatar
I am using my stock 5 speed untill I find a M5OD
Old November 7th, 2008, 07:54 AM   #4
silveranger93
silveranger93's Avatar
I put a 4.0L in my old '88 after I blew the 2.9. It's pretty straightforward. About as easy an engine swap as you can do. Your stock fuel pump will work fine, there's no need to change that. As long as you have the PCM, wiring, radiator and exhaust it will be pretty easy. Good luck on trying to get that trans to last though.
silveranger93 is offline   Reply With Quote
Old November 7th, 2008, 08:17 AM   #5
holeshot13
holeshot13's Avatar
I am not worried about the trans when it breaks I will find a new one
Old November 8th, 2008, 09:47 PM   #6
DeRanged mudder
completly insane
DeRanged mudder's Avatar
Send a message via Yahoo to DeRanged mudder
The wiring is not just a plug in. It requires some splicing. Otherwise there is nothing to it.
DeRanged mudder is offline   Reply With Quote
Old November 9th, 2008, 01:22 AM   #7
Never_Evil
Yes as everyone else said, the wiring and computer is your biggest thing to get in there, however the 4.0 is based on the original 2.8l which was then bumped up to the 2.9l. The 4.0 is just a stroked 2.9, so keep it around if you need any quicky parts off it.
Page generated in 0.18347 seconds with 44 queries
