79 F-150 Dana 44 and 9" with 4.88s SOLD!! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 5th, 2008, 03:55 PM   #1
Pete M
Comanche Addict
Pete M's Avatar
Default 79 F-150 Dana 44 and 9" with 4.88s SOLD!!
SOLD!!!
I'm finally to the point of selling the 4.88 axles.
From a 1979 Ford F-150 (coil springs) so they are full width (roughly 65 inches WMS-to-WMS) and have cast wedges up front (not welded). I never got a chance to use them, but was told they came from a running truck that was being parted out. Decent condition overall (better than the axles I'm using now). Track bar hole looks to be in good shape. One of the hubs is missing. Brake parts are all there. Rear diff is welded up, front is open. I may be able to get some stock radius arms and frame brackets and other nic-naks if you need them.
Looking for $580 for the pair.
I'm located about 20 minutes south of Detroit in Riverview, MI 48193.
Also, I can accept payment through paypal.
Thanks,
--Pete
Pete M is offline
Old November 9th, 2008, 11:55 PM   #2
98-S10-lifted
98-S10-lifted's Avatar
is the front setup for leaf or coils?
98-S10-lifted is offline
Old November 10th, 2008, 12:00 AM   #3
Pete M
Comanche Addict
Pete M's Avatar
Coils. Came from a fullsize Bronco.
--Pete
Pete M is offline
Old November 12th, 2008, 07:24 AM   #4
ppkaprince98
Size Matters (.)(.)
ppkaprince98's Avatar
Can you give us the WMS-WMS of each please.
ppkaprince98 is online now
Old November 12th, 2008, 12:41 PM   #5
Pete M
Comanche Addict
Pete M's Avatar
Should be roughly 65 inches.
--Pete
Pete M is offline
Old November 12th, 2008, 03:40 PM   #6
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
trade for mile marker PE8000 winch. complete with cable,control box, remote, fairlead and hook and hardware. only used a couple times on the front of my samurai? great shape!
RDK_YJ88 is online now
Old November 16th, 2008, 01:04 PM   #7
MJ_Silver_1988
MJ_Silver_1988's Avatar
Send a message via AIM to MJ_Silver_1988
would you sell just the 9" with 4.88 if so how much
MJ_Silver_1988 is offline
Old November 17th, 2008, 10:55 AM   #8
Pete M
Comanche Addict
Pete M's Avatar
Not quite yet. I still hold out hope of selling them as a pair.
--Pete
Pete M is offline
Old November 17th, 2008, 02:24 PM   #9
s.hembree
s.hembree's Avatar
Where are you located? Mapquest shows more then one Riverview in MI
s.hembree is offline
Old November 18th, 2008, 08:22 AM   #10
78cj7
build it break it learn
78cj7's Avatar
What is the bolt pattern on these axles and do you know if the cast in perches can be cut off for spring mounting?
78cj7 is offline
Old November 18th, 2008, 10:19 AM   #11
ttocsnekia
Fawkin' Noobs
ttocsnekia's Avatar
Originally Posted by Pete M View Post
1979 Ford F-150
= 5 x5.5
= part of axle tube
Bump for a good set of axles
Scott
ttocsnekia is offline
Old November 18th, 2008, 11:35 AM   #12
Pete M
Comanche Addict
Pete M's Avatar
I've been told that it's possible to weld perches on to the tops of the wedges (it's all steel afterall), but it's impossible to completely remove them without retubing the axle. The axle tubes are not continuous through the cast wedges.
--Pete
Pete M is offline
Old November 18th, 2008, 07:52 PM   #13
78cj7
78cj7's Avatar
I've been told that it's possible to weld perches on to the tops of the wedges (it's all steel afterall), but it's impossible to completely remove them without retubing the axle. The axle tubes are not continuous through the cast wedges. --Pete
Thanks, thats what I was wondering
78cj7 is offline
Old January 5th, 2009, 11:05 PM   #14
thrill20
thrill20's Avatar
You ever get to the west side? GR area?
thrill20 is offline
Old January 6th, 2009, 02:34 PM   #15
Pete M
Comanche Addict
Pete M's Avatar
I'd be willing to deliver if you cover most of the diesel, but no, it's not a regular drive of mine.
--Pete
Pete M is offline
Old January 29th, 2009, 04:56 PM   #16
low900rr
low900rr's Avatar
almost looks like the wedges are welded on???
low900rr is offline
Old January 29th, 2009, 05:29 PM   #17
Pete M
Comanche Addict
Pete M's Avatar
Nope. They are indeed of the cast variety.
--Pete
Pete M is offline
Old February 8th, 2009, 03:32 PM   #18
Pete M
Comanche Addict
Pete M's Avatar
Don't fear the Ford radius arms, I've been using them to great effect under my MJ.
Pete M is offline
Old March 30th, 2009, 12:27 AM   #19
MJ_Silver_1988
can the guts and knuckles and everything on the front axle be swapped over to a 79 f-250 dana 44 to eliminate the cast wedges bc i have that axle and if it can be done i might be interested in the whole package. these will be under my MJ. (the front i have is a 79 F-250 Dana 44 Hi Pinion Driver side 8 lug no lockouts)
Old March 30th, 2009, 12:33 AM   #20
bigblockford79
Big Block Ranger
bigblockford79's Avatar
yes you can switch the differentials as they are the same. I do believe however that the axle shafts on the 8 lug version are a different length than the 5 lug version.
bigblockford79 is offline
Page generated in 0.40000 seconds with 83 queries
