Wont start/idle... HELP PLEASE!!! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 4th, 2008, 09:25 PM   #1
rentalrider
rentalrider's Avatar
Default Wont start/idle... HELP PLEASE!!!
OK, just started this tonight. '86CJ7 with a stock fuel injected '86 mustang 5.0. Started fine. Drove it 1/2 hr. Made several stops. Started fine each time. Drove about an hour through woods/trails, stopping once to jump shoot a goose . Got home and let it set for 45min or so. Started hard. Turned over easily, but no fire, then tried again and it started, ran rough for a couple seconds and then was fine. Trail rode for 1/2hr, then stopped for 15min to vote. Came back out and wouldn't start. Turns over well, but nothing. Towed it home. Good spark, pump is one year old and sounds as typical. Finally got it started and it would rev fine, but not idle. Wanted to drop down REAL low, then back up to normal. All at about 1-2 second intervals. Will eventually stall if you don't gas it. Engine is fuel injected, otherwise feels like a choke issue. What is the component that tells the computer how much fuel is needed? My car has a throttle position sensor, would this have same system? Sorry for the long post, any help would be appreciated... geese are flying!
Old November 4th, 2008, 09:34 PM   #2
mudd_jumper
mudd_jumper's Avatar
Sounds like a TPS is messing up. You would have to find it on the motor and Ohem it out and see what it shows?
Old November 5th, 2008, 07:08 AM   #3
rentalrider
Before I tear into it... any other ideas?? I'll be testing the TPS this am.
Old November 5th, 2008, 07:14 AM   #4
blownexploder94
Todd
blownexploder94's Avatar
Ya sounds kinda like the TPS..... i have a 4.6 and when the egr got hung up it did the real low idle crap.... but never had a problem with starting.
Old November 5th, 2008, 07:29 AM   #5
rentalrider
EGR... never thought of that... refresh me, what exactly does that do? 'cause now it starts fine now that it's cooled off.
Old November 5th, 2008, 07:33 AM   #6
blownexploder94
Todd
Exhaust gas recirculation valve
Page generated in 0.26726 seconds with 41 queries
