SM465 4 Speed Trans and NP205 T Case was in a TJ $300 (SOLD) - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 4th, 2008, 07:14 PM   #1
TiresT
I'ld Rather Be Wheelin
TiresT's Avatar
Default SM465 4 Speed Trans and NP205 T Case was in a TJ $300 (SOLD)
SOLD!
One Ton Jeep TJ Trans Setup $300
SM465 4-Speed Trans (1st Granny Gear)
NP205 Transfercase (Passenger drop, Gear to Gear w/ fixed Yoke)
Flywheel
Clutch (Shot)
Pressure Plate (Heavy Duty)
Bell Housing (Chevy SB or BB)
Shifters (Trans shifter modified to fit in a TJ)
Trans Shifter Boot
Crossmember (Out of Chevy Truck)
Hydraulic Clutch Master and Slave Cylinders
Brass Bushing that goes in the crank
Measures 37.5" from the bellhousing to the rear drive shaft yoke
I had this setup in my 97 TJ with Dana 60s. The Granny 1st gear works extreemly well with 4.11s and 38s. Decided to put in a auto trans when it was time to change the clutch.
Pickup in Gaylord MI 49735
PM Me
Name:	TJ Trans.JPG
TiresT is offline
Old November 9th, 2008, 08:50 AM   #2
TiresT
TiresT's Avatar
Lowered the Price!
$300
TiresT is offline
Old November 10th, 2008, 08:24 AM   #3
TiresT
TiresT's Avatar
Hear you go 1 ton guys!
TiresT is offline
Old November 11th, 2008, 10:35 AM   #4
TiresT
TiresT's Avatar
Somebody needs this
TiresT is offline
Old November 11th, 2008, 12:12 PM   #5
two_much_talk
sit down shut up and ...
two_much_talk's Avatar
pm'd you .
two_much_talk is offline
Old November 11th, 2008, 12:39 PM   #6
TiresT
TiresT's Avatar
Originally Posted by two_much_talk View Post
pm'd you .
Back at ya.
TiresT is offline
Old November 11th, 2008, 01:05 PM   #7
boggin-machine
boggin-machine's Avatar
pm ktownjeep
hes looking for parts for his tj.
boggin-machine is offline
Page generated in 0.22823 seconds with 45 queries
