jeep won't shift into 4x4 high - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 17th, 2005, 04:19 PM   #1
mrclean
Silver Lake
mrclean's Avatar
Default jeep won't shift into 4x4 high
just like it says. Will go into 4lo, 2hi, neutral, but not 4x4 hi. Sometimes I can get it to go in but it just last a second. Checked the linkage and it doesn't appear to be shifted or have moved. Any suggestions?
mrclean is offline   Reply With Quote
Old November 17th, 2005, 04:52 PM   #2
shawn
Resident HVAC/R Jambi
shawn's Avatar
Is this happening after a SYE install?
Old November 17th, 2005, 04:55 PM   #3
mrclean
Silver Lake
mrclean's Avatar
sye was done a while ago. Has the adapters to drop the shift linkage too.
Old November 17th, 2005, 05:16 PM   #4
Tonka
Tonka's Avatar
tj or xj?
(yj's usually don't have an issue since the shifter is bolted to the t-case/trans)
Old November 19th, 2005, 01:57 PM   #5
ttms91xj
nothing original here
ttms91xj's Avatar
Send a message via AIM to ttms91xj
i've been having the same problem...but i am looking into getting a 4x4 posi kit, which bypasses the crappy vacuum motor and ensures that when you want to be in 4x4, it will be in 4x4...look into it, quadratec sells the kit for 200 bucks, give or take
ttms91xj is offline   Reply With Quote
Page generated in 0.21341 seconds with 38 queries
