Older CJ-5 Frame $100 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 4th, 2008, 10:23 AM   #1
hanser
hanser's Avatar
Default Older CJ-5 Frame $100
Not sure what year this frame is, best guess is 72-75 CJ 5. wheelbase is aprox 83". The frame is in very good shape, except for 3 problem areas in the rear. I took pictures of the bad areas, the rest of the frame is in great shape.
Includes steering box, Rear axle and leaf springs. Rear axle is flanged Dana 44 but pinion bearings are seized. Needs new ring & pinion & bearings. Front axle is now gone, I sold it separately.
I would like to get $100 for it, but I will consider trades. I'm interested in parts for my 86 CJ7 or my 94 ZJ.
pics:
ID:	33173   Click image for larger version
ID:	33174   Click image for larger version
ID:	33175   Click image for larger version
ID:	33176   Click image for larger version
Last edited by hanser; December 15th, 2008 at 06:35 PM. Reason: updated: front axle now gone
hanser is offline   Reply With Quote
Old November 4th, 2008, 10:35 AM   #2
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
can you check and see what gear ratio please?
Old November 4th, 2008, 11:23 AM   #3
hanser
hanser's Avatar
I think the gear ratio is 3.73 The front ring gear is stamped 41-11 (tooth count). I assume the rear is the same, but the rear gears and bearings need to be replaced anyway. (see original post)
Old November 4th, 2008, 12:30 PM   #4
Jeepaholic
Jeepaholic's Avatar
My buddy needs just the 3:73 front and I want the rest
Old November 4th, 2008, 02:29 PM   #5
Yes, that is a 72-75 frame. 3.73s were by far the most common in them.
Old November 5th, 2008, 11:39 AM   #6
hanser
hanser's Avatar
Thanks for confirming my guess
Old November 8th, 2008, 10:14 AM   #7
hanser
hanser's Avatar
ttt
Old November 10th, 2008, 01:43 PM   #8
hanser
hanser's Avatar
bump
Page generated in 1.93871 seconds with 48 queries
