Where to buy holley jets? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 1st, 2008, 07:15 PM   #1
jeepxj2007
Send a message via AIM to jeepxj2007
Default Where to buy holley jets?
Hello, I have a Holley 4160 4bbl 390cfm vacuum secondaries, on my 258 4.2 in my Wrangler...its not built huge or nothing...just DUI distrib. K&N, headers, flexalite fan and the carb...and it burns really really rich...I am looking at getting the jet kit to play around with it because the carb came off a chevy v-8 and I believe it was jetted for that...a few people on jeepforum.com said that they use size 58 jets on the 350cfm 2bbl and had good results and to start around there...the only problem is every jet kit I found is from 64-99..you can buy the smaller ones individually but I can't find a kit for them...they want 7.99 a pair for the individuals and I don't want to buy a bunch of them to play around when a kit is 50ish dollars...so does anyone have any suggestions of where to get some smaller ones? or perhaps someone is running a similar setup and can suggest what jet size to use...I have no clue what is in it right now...it was also just rebuilt by me a month ago.
jeepxj2007 is offline   Reply With Quote
Old November 1st, 2008, 08:06 PM   #2
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
your local napa may carry them... otherwise jegs/summit or other performance houses.
Old November 1st, 2008, 11:44 PM   #3
jeepxj2007
yeah I found the pairs and kits at jegs/summit...but for some reason I can't find a kit for jet sizes below 64...I will try napa
Old November 6th, 2008, 09:18 PM   #4
merr6267
More boost than yours:)
merr6267's Avatar
Check your power valve . . .
Is it rich when you're at wide open? If not, you may have a blown power valve. Replace and enjoy normal driving again.
merr6267 is offline   Reply With Quote
Page generated in 0.22473 seconds with 35 queries
