SnoFARI 2009 - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > General 4x4 Stuff > SnoFari 2009
SnoFari 2009 Sponsored by GL4x4. Sanctioned by GLFWDA. Hosted by SoFO
Old October 31st, 2008, 12:16 PM   #41
Stan
I got a gold chain
Stan's Avatar
Originally Posted by wilson23 View Post
i want in but i need to know the loc its my first time
Location?
West Branch.
Stan is offline   Reply With Quote
Old October 31st, 2008, 12:17 PM   #42
clarkstoncracker
lol
clarkstoncracker's Avatar
Originally Posted by Stan View Post
don't be sad.
Maybe you should stop being so cheap, man up and get her some labioplasty.
Old October 31st, 2008, 12:18 PM   #43
Stan
I got a gold chain
Stan's Avatar
I didn't know Leanz was blown out?
Unless you mean my wife. She doesn't need it.
Old October 31st, 2008, 12:23 PM   #44
snocross2xtremes
snocross2xtremes's Avatar
what kinda wheel do they do on this event? is it tight narrow trails or open stuff for a big full size truck?
Old October 31st, 2008, 12:25 PM   #45
Renegade II
Coil springs are for pens
Renegade II's Avatar
My H1 made it through the pre run without any dents last year, truck should be no prob
Old October 31st, 2008, 12:28 PM   #46
silverxj
Recovering XJ owner
silverxj's Avatar
It's West Branch.
There's some tight, some open, hills and yes, a full size should be okay.
Unless you're talking F250 Diesel w/ 50psi in the tires .. then you might have a problem. (Ask me how I know)
Old October 31st, 2008, 12:31 PM   #47
clarkstoncracker
lol
It depends on the weather.
Last year a couple groups went out friday night and saturday night to do some trails. There was a fresh 15" of snow, so even the "easy" trails were tougher then normal.
SoFO pulls permits to do hill climbs that are normally illegal, so there is a lot more to do then normal.
Last year there were groups broken down into different levels, so there is something for everybody.
Old October 31st, 2008, 01:56 PM   #48
cyrus
grow old, not up.
cyrus's Avatar
Originally Posted by silverxj View Post
It's West Branch.
how do you know?
R/T
'99xj
01 PSD
'97tj
Southern Michigan Rockcrawlers
"I spent most of my money on alcohol, women and jeeps . . . the rest I just wasted. . ."
cyrus is offline   Reply With Quote
Old October 31st, 2008, 02:16 PM   #49
junk90xj
ALLPRO AUTO
junk90xj's Avatar
are the gl4wd requirements relaxed or not? i have no e-brake and they dont allow pinion brakes.
also must you be a gl4wd member?
http://www.apalansing.com/
Old October 31st, 2008, 02:18 PM   #50
tom tom
tom tom's Avatar
what are the saftey requirements ? where do I find them ??
tom tom is offline   Reply With Quote
Old October 31st, 2008, 02:19 PM   #51
junk90xj
ALLPRO AUTO
junk90xj's Avatar
http://www.glfwda.org/forms/Safety_C...vised_3_06.pdf
Old October 31st, 2008, 02:26 PM   #52
kixx007
Certified Ypsilantian
kixx007's Avatar
You never know, I might climb in your Jeep during inspections and pull the ebrake.
But I will probably be more concerned with your tow points, and the rest of your recovery gear.
kixx007 is offline   Reply With Quote
Old October 31st, 2008, 02:27 PM   #53
clarkstoncracker
lol
I don't have an e-brake, but I've been on numerous glfwda runs.
Old October 31st, 2008, 02:40 PM   #54
Yes, you MUST be a GLFWDA member.
RE the requirements................... ahem............. The rules are guidelines of what is deemed safe. There will not be a vehicle safety inspection.
I will be one of the trail leaders for the event. Here's what I do; I will do a quick visual of your vehicle & point out any OBVIOUS issues. IE broken tail light that might get us pulled over, bulging tire, etc. I am not going to crawl under your vehicle to do a safety inspection for a couple of reasons. First, I am not a certified mechanic and I don't have the credentials to determine if your brakes are functional, your roll bar is adequate, etc. Second, I EXPECT you to be a man of your word that your vehicle is up to snuff.
Now, where I do have an issue is with tow points. If you don't have visually quality tow points, you're not going on my run.......... PERIOD. If you have a trailer hitch that's half falling off and I know we are going someplace where you will be using it, I'll tell you no. Sorry. Safe recovery should have no grey areas.
In addition, I will set the standards for those on my run. In other words, again, if we are going somplace that I know will require a certain tire size or lockers, I insist on it. Why? Sure, you may say "I want to try that" and you may even make the obstacle with only one locker. The flip side is, if you become the boat anchor for the group, is that fair to the other folks on the run?
Hope this helps.
Jim
Old October 31st, 2008, 02:48 PM   #55
cyrus
grow old, not up.
cyrus's Avatar
Nicely put, I may borrow that when I lead trails.....
Thanks Jim.
R/T
'99xj
01 PSD
'97tj
Old October 31st, 2008, 02:53 PM   #56
kb8ymf
Not as old as Whiterhino
kb8ymf's Avatar
Hope this helps.
Jim
dam you're a tough little slave driver aren't you!
j-kb8ymf
kb8ymf is offline   Reply With Quote
Old October 31st, 2008, 03:00 PM   #57
Renegade II
Hope this helps.
Jim
Jim's serious about tow points. I remember a few times Mr. boat anchor checked our tow points by having us tow him back to his trailer
Old October 31st, 2008, 03:12 PM   #58
Hey Mike.........................
Old October 31st, 2008, 03:29 PM   #59
kixx007
kixx007's Avatar
I am a certified mechanic and I will be crawling under EVERY vehicle, with pockets full of paper clips and zip ties.
Old October 31st, 2008, 03:31 PM   #60
kixx007
kixx007's Avatar
And by the way, for all those who want "in". There is an initiation if you have never attended. Please arrive at the hotel by 6:30PM on Friday Jan. 9th. Wait by the pool, we will meet you there.
Page generated in 0.47215 seconds with 84 queries
