1993 Ranger 4x4 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 29th, 2008, 09:14 PM   #1
KJDan
KJDan's Avatar
Default 1993 Ranger 4x4
Need to know the easiest way to change front axle u joints and dose anyone have a used lift or know where i can get one cheap
KJDan is offline   Reply With Quote
Old October 29th, 2008, 09:15 PM   #2
KJDan
KJDan's Avatar
Truck is a 1993 Ext. cab short box 4.0L auto trans. with a 3" body lift
Old October 29th, 2008, 09:17 PM   #3
04 EDGE
Floor Shift Maddness!
04 EDGE's Avatar
why do you need a lift?
have you ever had a 4x4 apart?
Old October 30th, 2008, 03:54 AM   #4
KJDan
KJDan's Avatar
I have not had it apart and I'm not looking for a lot of lift just more ground clearence and taller tires. My friends are all running 35s and we tend to climb over a lot of logges but I'm only looking to go to 33s
Old October 30th, 2008, 09:43 AM   #5
KJDan
KJDan's Avatar
Anyone got a lift for sale for this truck
Old October 30th, 2008, 10:06 AM   #6
silveranger93
silveranger93's Avatar
I've got a 6" Skyjacker kit. I have all the lift brackets for the front, the pitman arm and springs. I have the front and rear shocks, they are used but are still good. I just don't have the rear blocks. I'm looking for $200 for all of it.
silveranger93 is offline   Reply With Quote
Old October 30th, 2008, 02:31 PM   #7
booblinker
Sore and Tired 24/7
booblinker's Avatar
Take the wheel, caliper, rotor and spindle off, then pull the shaft out the hole and take it in to have a new u-joint pressed in. Also you can fit 33s with a 3" body lift with minor rubbage, check out therangerstation.com
Page generated in 0.21117 seconds with 44 queries
