Bike lights Pics Added 11/04 - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > Other Stuff > The Great Outdoors
The Great Outdoors Guns, Cannons, Fishing, Camping, and other fun stuff
Old October 29th, 2008, 08:57 AM   #1
clint357
Web Wheeler Extraordinair
clint357's Avatar
Default Bike lights Pics Added 11/04
One is a 3w led with 240 lumens and 4 interchangable beam patterns and the other is a 12w, 900 lumen verson with an 8 degree fixed lens and 100% 30% and 10% power settings. I don't have battery packs picked out yet, but I'm using Night Rider connectors. Anyone have suggestions and/or insight into gripes about your current light source? So far I have about $50 into the big one and $20 into the small one. I'm thinking about putting a reinforced lens plate on the bigger one to put on a vehicle since they are as bright as a 35w H3 hella hallogen. Let me know if any of you want to try one of these out against your current light.
Well here they are.
clint357 is offline   Reply With Quote
Old October 29th, 2008, 08:58 AM   #2
JEEPR
Playing Possum
JEEPR's Avatar
The sun?
JEEPR is offline   Reply With Quote
Old October 29th, 2008, 09:34 AM   #3
clint357
clint357's Avatar
Originally Posted by JEEPR View Post
The sun?
These are mainly used when the sun is not available.
Old October 29th, 2008, 06:27 PM   #4
JEEPR
Playing Possum
JEEPR's Avatar
When I worked at a bicycle shop, we sold a lot of TurboCat lights. They are nice because the battery pack is separate from the light and rechargeable. You can actually see with them. The way to go is one on the bars and one on the helmet. They are a lot of money unless you plan on doing some real off-road stuff.
I was usually more worried about someone else seeing me, so I used red LEDs on the rear and white or yellow LEDs on the front. The self-contained battery powered ones. Residual light around the city is good enough to navigate a bicycle.
Old October 29th, 2008, 06:51 PM   #5
clint357
clint357's Avatar
Yeah, the 240 lumen one is bright and the 900 lumen unit is brighter than my high beams on my XJ. I'll have external packs on both of them.
Old October 29th, 2008, 07:02 PM   #6
L4CX
Out for the Summer!
L4CX's Avatar
I use two HaborFright small LED flashlights that are strapped on to my fork with hair ties. Then a Cheap Blinking rear light. It works for my bitch black ride to the bus garage in the morning.
L4CX is offline   Reply With Quote
Old November 4th, 2008, 09:48 PM   #7
clint357
clint357's Avatar
btt for pics
Old November 4th, 2008, 10:25 PM   #8
FlatFender
Tap Tap Splat
FlatFender's Avatar
get some beam shots dude, and weight with batteries.
Old November 5th, 2008, 05:41 AM   #9
clint357
clint357's Avatar
What batteries? I don't have any yet. I'll get the weight of the light itself and then post some battery weights vs. estimated run time.
Old November 5th, 2008, 08:53 AM   #10
clint357
clint357's Avatar
The light is 110g and the battery I'm thinking about running is 185g and will give 2 hours run time on high, 6 on meduim, and 20 on low. The light just has a 10-24 thread inside for whatever kind of mount you want. I'll try to get some beam shots tonight too. I also put this beside a 10W Night Rider HID and it was at least as bright if not brighter. It also gives off a pure while light, while the night rider seems to have a blue tint to it. If anyone wants one of these, I'll sell them at cost right now $50 for the light and about $70 for the battery pack and charger if anyone is interested.
Old November 6th, 2008, 04:49 AM   #11
clint357
clint357's Avatar
Here's the best I could get with my point and shoot. I'll try to get a better one, or doctor this one, because It looks quite a bit brighter than this in person. The white garage is about 140' away and it was lit up quite well. It seems to be about as bright as my 3" x 5" KC lights on my Jeep.
Old November 6th, 2008, 10:38 PM   #12
FlatFender
Tap Tap Splat
FlatFender's Avatar
That looks awesome. What LED are you using? Cree?
Old November 7th, 2008, 06:18 AM   #13
JEEPR
Playing Possum
JEEPR's Avatar
Wow, impressive.
Old November 7th, 2008, 07:29 AM   #14
clint357
clint357's Avatar
SSC P7. I need a little more heatsinking though. I tried them at full power last night for about 20 minutes and the thermal switch cut them off. Hopefully I'll be able to remedy that tonight though.
Old November 7th, 2008, 07:37 AM   #15
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Need power draw figures for battery life - looks like a winner though.
@clarkstoncracker
Old November 7th, 2008, 08:21 AM   #16
clint357
clint357's Avatar
About 13w. takes inputs from 5v to 15.5v and adjusts the amperage accordingly. At five volts it will pull about 2.7A.
Old November 7th, 2008, 09:32 AM   #17
FlatFender
Tap Tap Splat
FlatFender's Avatar
were they just sitting on a table or something when you tested them? I had a homebrew LED that would get hot just sitting, but with the airflow from being attached to my bike it stayed really cool.
Old November 7th, 2008, 09:47 AM   #18
jimhri
jimhri's Avatar
can these be modified to run off a automotive electical system?
could be effective as back up lamps or mobile flood lamps if i get a flat after dark.
please pm with your ideas.
jim
jimhri is offline   Reply With Quote
Old November 7th, 2008, 10:57 AM   #19
clint357
clint357's Avatar
I'm going to test them tonight with some good air current to see how they work. I'll still add a heatsink though just to make sure it doesn't happen.
Old November 7th, 2008, 11:41 AM   #20
mtnbikinbryno
mtnbikinbryno's Avatar
Send a message via AIM to mtnbikinbryno
Damn, nice work Clint. Looks really good.
mtnbikinbryno is offline   Reply With Quote
Page generated in 0.65324 seconds with 83 queries
